I receive Aero Lag when opening and closing windows in Windows 7
2009-11-03T19:47:26+00:00
original title:  Aero Lag when opening and closing windows in Windows 7
UPDATE!!!!!!!!!!!!!!!!!!
OK since we've got the ball rolling here, I am editing this to better reflect what is going on. The below links are just a few out of hundreds of post you will find on the internet about this Aero Lag. Some offer workarounds and some don't. I just Googled Aero Lag and this was from the first page.
If you have the same problem, please provide:
  1. What type of graphics card you have.
  2. What kind of drivers are you using (Win7 preinstalled or manufacturer's drivers)
  3. Was your version of Win7 an update or clean install.
  4. What motherboard you have.
From the sounds of it, Microsoft is looking for a fix.
I also ask for a forum admin to make this a sticky as many people are experiencing this problem.
-Randall
http://www.sevenforums.com/performance-maintenance/22313-aero-lag-good-system.html
http://www.sevenforums.com/graphic-cards/21250-win7-aero-windows-have-choppy-delay-when-opening.html
http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/a013396d-8953-4e32-8d13-f2d119cd730d
http://www.flamehaus.com/bbs/-vp3478764.html
http://www.youtube.com/watch?v=YKNj_90E_PI
http://www.hardforum.com/showthread.php?t=1465844
http://windows7forums.com/windows-7-hardware/1549-windows-7-video-lag.html
http://windows7forums.com/windows-7-software/23315-gaming-video-lag-choppyness.html
http://windows7forums.com/windows-7-support/5287-aero-lags-when-open-new-programs.html
http://forum.eeeuser.com/viewtopic.php?id=66007
http://www.neowin.net/forum/lofiversion/index.php/t787172.html
http://www.youtube.com/watch?v=YWdVrSUhvLE
Randall
2011-01-13T22:36:16+00:00
**Have solved my problem withAeor lag.**Reinstall Windows 7 U64 twice with new/old driver.
Replaced Gforce 8800GTX with Gforce GTX480.
Have spent many days on this problem without a solution.
But here is a very simple solution that works for me.
I removed the USB extension cablefor my CreativeHS-1200WirelessUSB Gaming Headset.
Aero lags when Iused USB extension cable and headset charging.
Without USB extension cable, everything is fine.
So it think itis a voltagedrop in the USB extension cable,causes the system to lag. ?
Hope it can help.
Sincerely,
Dennis Psilander
291 additional answers
    2009-11-05T23:51:09+00:00
    re: BAM! The screen went black and then came back on a few seconds later, then it was laggy
    For what it's worth, I have a Dell 8300 system that used to have this exact problem until I swapped out the ATI Radeon 9700 video card for a different model. (And strangely, this card worked perfectly under XP on the same system, so it was not the card per se!) This same system, while not exactly high-powered by today's standards, now runs Win7/Aero flawlessly on a 9600-series Radeon card without any appreciable lag, on 1.5GB of RAM. I also run Win7/Aero on my Dell XPS laptop (running an Nvidia 8600) with no lag.
    I believe there are multiple contributing factors here, so a one-size-fits-all solution is unlikely. While troubleshooting, you might try:
    1. Disable overclocking and other BIOS trickery (disabling the "Multi step OC booster" BIOS option has helped some people)
    2) Try running with WHQL-certified WDDM drivers.
    1. If all else fails, try swapping graphics cards. This was the only thing that worked for me.
    2009-11-06T03:15:34+00:00
    Well I reinstalled and have yet to had the problem return, but maybe this could be a fix for others.
    Randall
    2009-11-06T16:00:09+00:00
    Hey everyone,
    Anyone that experienced or is experiencing this issue can you please provide the following information about your system?
    We're checking to see if there's any correlation between the issue and specific hardware / drivers.
    Can you please provide:
    1. Video Card make and model
    2. Which driver you are using (Built in Windows 7 or downloaded Nvidia.com driver)
    3. Was the installation of Windows 7 a "Format/Reinstall" or an "Upgrade from Vista"
    Thanks!
    If you find that my answer was what you were looking for, please remember to click the "mark as answer" box below!
    2009-11-06T18:19:39+00:00
    Hi again:
    1. nVidia GeForce 8600M GT
    2. 186.81 driver from nvidia.com
    3. Clean instalation
    Looking forward to solve this
