Error Code 52 - USB ports not recognizing connected USB devices stating that "Windows cannot verify the digital signature for the drivers required for this device"
2010-03-07T20:11:51+00:00
Original Title: Error Code 52 - USB ports not recognizing connected USB devices
I have recently purchased a new laptop with Windows 7 and had no initial problems connecting USB devices (mouse, hard drive, camera etc.) to the ports. Since installing a number of windows updates none of my USB ports will now recognize any hardware that is connected to them.
The error code is quoted as follows **"Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52".**I have been into Device Manager and notice that each USB icon has a yellow exclamation mark icon next to it. I have uninstalled each USB port and scanned for hardware changes which has no positive affect. I have also tried to 'Update driver software' in device manager and again this tells me that the driver is up-to-date for each USB port.
Any help would be much appreciated.
2010-03-10T04:29:36+00:00
Hi slark101,
Boot into Advanced Boot Options and disable driver signing checking.
The Advanced Boot Options screen lets you start Windows in advanced troubleshooting modes. You can access the menu by turning on your computer and pressing the F8 key before Windows starts.
Disabling driver signature enforcement has helped a lot of users in fixing the issue.
You may also delete the USB "Upper Filter" & "Lower Filter" Entry and check if that helps.
Before we go any further, please first backup the Registry.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
How to back up and restore the registry in Windows
http://support.microsoft.com/kb/322756/
1.   Click “Start”, type “regedit” (without quotation marks) in the “Search” bar and press Enter.
Note: If UAC (User Account Control) pops up, please accept it.
  1. Right click “Computer” (the root node) in the left pane, click “Export” under the “File” menu, choose “All” under “Export range”, and select “Desktop” in the “Save” in box and type backup in “File Name”. Click “Save”.
**Note:**The backup file is on the Desktop and named backup.reg. We can simply restore the registry by double-clicking the backup.reg file.
  1. Click “Start”, type “regedit” (without quotation marks) in the “Search” bar and press Enter again.
  2. Locate the “UpperFilters” value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{36FC9E60-C465-11CF-8056-444553540000}
  1. On the “Edit” menu, click “Delete”, and then click “OK”.
  2. Locate the “LowerFilters” value under the same key in the registry:
  2. Quit Registry Editor and restart the computer.
Hope this helps.
Gokul - Microsoft Support
[If this post was helpful, please click the "Vote as Helpful" (green triangle) button. If it helps in resolving your issue, click "Propose As Answer" or "Mark as Answer" button. By proposing/marking a post as Answered, or Helpful you help others find the answer faster.]
42 additional answers
    2011-05-02T00:59:20+00:00
    If you, or anyone else, have installed Service Pack 1 using the executable installer, there is a reported USB driver bug.
    The following link has more information and a possible fix (USB Driver Update Fix):
    forums.mydigitallife.info/thread···-fix-it)
    One of the effects of the bug may be that the USB 2.0 driver becomes unsigned.
    Running the USB Driver Update Fix will ensure the USB drivers in question are properly updated
    2011-05-08T09:25:40+00:00
    thank you so much this actually worked for me!
    2011-06-20T03:58:16+00:00
    This worked for my usb issue but I want a perminent fix. Having to use advance mode to boot every time is a major pain. Anyone have any idea when a solid fix will be out for this?
    2011-07-04T20:54:06+00:00
    I'm experiencing this problem. If I run windows with the driver signing check disabled, all works fine. I tried uninstalling the USB controllers and editing the registry without success. I checked for the SP1 bug but my system is reported to be ok by the tool provided on the thread http://forums.mydigitallife.info/threads/24666-The-Windows-7-SP1-USB-Driver-Bug-(what-it-is-and-how-to-fix-it)
    Anyone got this fixed?
