send to desktop as shortcut missing
2010-04-07T18:58:45+00:00
When I right click a file or folder and select "Send To" the option of "Desktop (Create a Shortcut)" is missing. Windows 7 upgrade from Vista
2010-04-08T14:30:32+00:00
Hey driver1275,
Here’s how you can restore the missing item.
To restore the item, follow these steps:
1.     Click Start , type the following path and press Enter :
C:\Users\default\AppData\Roaming\Microsoft\Windows\SendTo
2.     Copy the file Desktop (create shortcut) from the Default user folder and place a copy in your user profile SendTo folder.
3.     The SendTo folder of your user profile can be accessed by typing shell:sendto in the Start-search box.
That should do the trick.
Regards,
Shinmila H - Microsoft Support
49 additional answers
  1. Deleted
    2013-01-29T20:26:02+00:00
    thanks sweet heart done the trick after ages trying
    2013-03-06T05:40:46+00:00
    Thank you so much
    problem solved
  4. Deleted
