send to desktop as shortcut missing
2010-04-07T18:58:45+00:00
When I right click a file or folder and select "Send To" the option of "Desktop (Create a Shortcut)" is missing. Windows 7 upgrade from Vista
2010-04-08T14:30:32+00:00
Hey driver1275,
Here’s how you can restore the missing item.
To restore the item, follow these steps:
1.     Click Start , type the following path and press Enter :
C:\Users\default\AppData\Roaming\Microsoft\Windows\SendTo
2.     Copy the file Desktop (create shortcut) from the Default user folder and place a copy in your user profile SendTo folder.
3.     The SendTo folder of your user profile can be accessed by typing shell:sendto in the Start-search box.
That should do the trick.
Regards,
Shinmila H - Microsoft Support
49 additional answers
    2012-04-03T19:00:44+00:00
    I have tried this but all that happens is instead of creating a shortcut when I click send to desktop, it creates a duplicate of the file.
    I have tried several times but the result is the same.
    2012-04-09T21:25:21+00:00
    in my SendTo foler of my user profile (shell:sendto shortcut) There is a Desktop (create shortcut) already. I delete it and copy the one from the other folder and it is STILL missing from my right-click menu
    2012-06-15T04:45:38+00:00
    I tried it from Start-Search too and it works
    2012-08-03T21:43:25+00:00
    Hey driver1275,
    Regards,
    I copied, drug, the deskktop shortcut from Shell to the desktop and brought it back to the right click menu.
