send to desktop as shortcut missing
2010-04-07T18:58:45+00:00
When I right click a file or folder and select "Send To" the option of "Desktop (Create a Shortcut)" is missing. Windows 7 upgrade from Vista
2010-04-08T14:30:32+00:00
Hey driver1275,
Here’s how you can restore the missing item.
To restore the item, follow these steps:
1.     Click Start , type the following path and press Enter :
C:\Users\default\AppData\Roaming\Microsoft\Windows\SendTo
2.     Copy the file Desktop (create shortcut) from the Default user folder and place a copy in your user profile SendTo folder.
3.     The SendTo folder of your user profile can be accessed by typing shell:sendto in the Start-search box.
That should do the trick.
Regards,
Shinmila H - Microsoft Support
49 additional answers
    2011-04-08T14:18:17+00:00
    Hey driver1275,
    Regards,
    I think you meant to click Start-->Run (Start-Search will not work as described)
    2011-04-20T16:48:26+00:00
    thanks it is very helpful
  3. Deleted
    2011-06-01T14:16:45+00:00
    I am having the same issue, I can complete step 1, but then wehn i go to step 2 my pc doesnt come up with anything once I get to the Send To portion.
    How can i fix this?
    Thank you!
