send to desktop as shortcut missing
2010-04-07T18:58:45+00:00
When I right click a file or folder and select "Send To" the option of "Desktop (Create a Shortcut)" is missing. Windows 7 upgrade from Vista
2010-04-08T14:30:32+00:00
Hey driver1275,
Here’s how you can restore the missing item.
To restore the item, follow these steps:
1.     Click Start , type the following path and press Enter :
C:\Users\default\AppData\Roaming\Microsoft\Windows\SendTo
2.     Copy the file Desktop (create shortcut) from the Default user folder and place a copy in your user profile SendTo folder.
3.     The SendTo folder of your user profile can be accessed by typing shell:sendto in the Start-search box.
That should do the trick.
Regards,
Shinmila H - Microsoft Support
49 additional answers
  1. Ramesh 181.9K Reputation points Volunteer Moderator
    2011-01-12T05:13:54+00:00
    What? this is not clear and doesn't work. very hard for me to work around.
    Tell us which part is not clear, and needs more explanation?
    Ramesh Srinivasan | The Winhelponline Blog
    Microsoft MVP, Windows Desktop Experience
    2011-01-16T13:14:10+00:00
    I have done the sugested fixes to noavail. do I need to reinstall windows 7?
    2011-01-21T20:03:47+00:00
    In this version of windows I do not see an option to type these commands. I only see a search box.
    2011-01-21T20:18:45+00:00
    Click the start button,
    If you type it will show up in the explorer search box.
