send to desktop as shortcut missing
2010-04-07T18:58:45+00:00
When I right click a file or folder and select "Send To" the option of "Desktop (Create a Shortcut)" is missing. Windows 7 upgrade from Vista
2010-04-08T14:30:32+00:00
Hey driver1275,
Here’s how you can restore the missing item.
To restore the item, follow these steps:
1.     Click Start , type the following path and press Enter :
C:\Users\default\AppData\Roaming\Microsoft\Windows\SendTo
2.     Copy the file Desktop (create shortcut) from the Default user folder and place a copy in your user profile SendTo folder.
3.     The SendTo folder of your user profile can be accessed by typing shell:sendto in the Start-search box.
That should do the trick.
Regards,
Shinmila H - Microsoft Support
49 additional answers
    2016-01-02T10:33:04+00:00
    Thanks mglassbob - that worked a charm.  I too had the "missing file"  already in the specified folder, so it was frustrating trying to find a solution.
    2016-01-04T07:11:08+00:00
    This Folder is empty please tell how to add "desktop (create shortcut)".
    and how to restore all that settings of send to folder
    2016-01-04T16:46:43+00:00
    SOME HOW I GOT ON WINDOWS 7 PROBLEMS PAGE ABOUT THIS PROBLEM, NEVER HAD A PROBLEM (ANY PROBLEM WITH WINDOWS 7). MY PROBLEM WAS WITH WINDOWS 10.--P.S. I SOLVED BY GOING BACK TO WINDOWS 7 PRO
    2016-02-01T17:52:43+00:00
    SAME HERE with windows 10.
    the desktop shorcut it in : C:\Users\default\AppData\Roaming\Microsoft\Windows\SendTo
    but still - its dont work .
