send to desktop as shortcut missing
2010-04-07T18:58:45+00:00
When I right click a file or folder and select "Send To" the option of "Desktop (Create a Shortcut)" is missing. Windows 7 upgrade from Vista
2010-04-08T14:30:32+00:00
Hey driver1275,
Here’s how you can restore the missing item.
To restore the item, follow these steps:
1.     Click Start , type the following path and press Enter :
C:\Users\default\AppData\Roaming\Microsoft\Windows\SendTo
2.     Copy the file Desktop (create shortcut) from the Default user folder and place a copy in your user profile SendTo folder.
3.     The SendTo folder of your user profile can be accessed by typing shell:sendto in the Start-search box.
That should do the trick.
Regards,
Shinmila H - Microsoft Support
49 additional answers
    2015-09-29T20:36:55+00:00
    Pin to start.
    Open start.
    Select item.
    Drag to desktop.
    2015-10-04T22:40:01+00:00
    I do not like Windows 10 at all, it is not user friendly.
    2015-12-14T18:20:21+00:00
    I have lost the ability to created a desktop shortcut as an option when I right click a file.  The answers to fixing this do not seem to work in Windows 10.  Is there another method to restore this option?  Thanks!!
    2015-12-15T12:35:56+00:00
    I HAVE TRYED FOR 3 MOUTHES TO FIX THIS PROBLEM. I THINK THE PROBLEM STARTS WITH MICROSOFT EDGE-(NOTE) I HAVE PAID 4 PEOPLE TO TRY AND FIX THIS PROBLEM.!!!! I USED THE SHORT CUT FEATURE ALOT WHEN SHOPPING ONLINE. I THINK I WILL GO BACK TO WINDOW 7 PRO OR LINIX?
