Western Digital External Hard Drive not Recognized by Windows XP: Does not show up in My Computer or Device Manager.
2010-05-13T01:16:46+00:00
My external hard drive does not run automatically when plugged into my USB port on my computer.  It is not recognized in my computer and it does not show up in Device Manager.  I have applied a hot fix for this problem and it was stated that problems are detected but after applying the hot fix the problem still exits!  HELP.  I went to Western Digital for this problem and they stated in their FAQ's that it is a Windows problem and that the drivers might be corrupted.  This is probably true as the device works perfectly on other computers.  Now what do I do?
2010-08-11T06:46:44+00:00
Here’s the actual steps needed to get your external USB drive assigned a letter in Windows XP if it does not show up in Windows Explorer:
1)     Right-click on “My Computer”
2)     Click “Manage”
3)     Double-click “Disk Management”
4)     You will probably see Disk 0 and Disk 1 for your primary hard drive. Go to lower right portion of box and scroll down until you see Disk 2. It is probably your USB drive without a letter.  It should show the size of the drive.
5)     Right-click in the left portion of that drive box (Disk 2)
6)     Click “Initialize” and “OK” in the next dialog box. This takes just a few seconds and it should now say “Online” in the “Disk 2” box.
7)     Right-click in the box to the right side of the “Disk 2” box (where it shows your disk drive size and says “Unallocated”.
8)     Click “New Partition” and a “New Partition Wizard” will open up.
9)     Click “Next”, then select “Primary Partition” and click “Next”.
10) Verify partition size (use entire disk size available unless you are creating multiple drives) and Click “Next”.
11) Assign drive letter (“F” is typical if CD-Rom is E) and click “Next”.
12) Format this partition with “NTFS”, “Default”, “New Volume” and click “Next”.
13) Then click “Finish” to exit the wizard and start formatting.
14) Be patient… this can take awhile (it took just over an hour for a 320GB drive).
15) When done, you should see an icon for your drive in Windows Explorer!
Hope this helps!!
Doc
42 additional answers
    2010-05-13T19:18:57+00:00
    This is truly a splendid answer with good step by step procedures, however, because I can't visually see the drive anywhere, on this computer I can't try the steps you have suggested.  I want to use this computer to transfer the files to a partitioned drive, the drive is 250 GB, and has room so that I can transfer files, and then format if I wish.  I guess I could use another computer to do this but my other one only has an 80 GB hard drive and is a much older computer, I could try Converting to NTFS, because as I said I already have files on the disk I would rather not erase.  but my computer skills are limited.  Thank you, coork, for these suggestions, and I will let you know if it works!
    2010-05-13T17:47:12+00:00
    hello
    have you initialized the external hd http://www.microsoft.com/windowsxp/using/setup/tips/advanced/ntfs.mspx
    Please click the Check Mark As Answered On This Page If this post helps to resolve your issue as it helps others who need quick access to Answers THANK YOU AND GOOD LUCK
