0x80042302 on system restore..
2010-02-24T05:46:54+00:00
I am having some problems with my laptop Windows 7 Home Premium pc. It has been working fine until my mouse pad stopped working properly, I tried to do several times a system restore and it finally worked.
My Norton Antivirus expired and I removed it from my computer using Revo Uninstaller, the next time I booted my laptop, my wireless connection was off. I checked in Device Manager only to find out that there were 'warning' triangles in the network adapters and in all of my Universal Serial Bus Controllers. I fixed that by disabling everyone of them, and enabling them again.
I installed a Windows Update, and after the install my laptop started acting weird. I cant listen to my music since it doesnt let me open it, I cant open my pictures, I cant  watch videos on youtube; no sound comes out at all, and it Im not able to even open the properties in my computer. I tried to do a system restore but it gave me the error above (0x80042302) saying " A Volume Shadow Copy Service component encountered an unexpected error. Check the Application event log for more information."
I tried with an antivirus to see if it might have something to do, but it didnt find any.. Any ideas on what might be wrong?..
Thanks..
2013-06-29T21:11:04+00:00
Try checking all your services.search on start search  services.msc
I had this problem too,had no audio, the error code in system restore and couldn't connect to the Internet .all my services was disabled so I changed them all to automatic and it worked like a dream. Hope this helps.
47 additional answers
    2010-05-15T01:13:07+00:00
    this thread is useless if the hard disks cant be populated which mine couldnt. re-installation is stupidly almost impossible without the system being restored first but even with system restore not working while you are logged in normally, system restore can still be used.
    X - press F8 to enter the recovery options while just after switching on
    X - select the "repair your computer" option
    X - obviously choose your keyboard layout and log in as you normally would
    X - then select system restore to restore your system
    X - additionally it may tell you after a short while that the restore hasn't worked but repeat this again using a different restore point if one is available, otherwise there is the option to scan the image too for any errors
    shortly after you can continue on using the backdated restore point or your could re-install windows again to make sure
    thanks all, hope this helps :D
    • Steven
    P.S the thread refers to dena's referral about the re-installation, its useful for those who are not in as deep a problem but doesnt initially help those who worse off, eg no internet connection, unable to install or un-install, no access to vital functions like control panel or windows update...and so on
    2010-05-25T17:47:02+00:00
    OK, I have the nearly identictal issue after an uninstall using revo, where my network icon shows i am disconnected, but I am in fact connected.  Also, I cannot re-install win7 and I cannot get to a restore point.  All error messages have been tried with restarting shadow services and net awareness, but with no results.  I tried a safe start and a cold boot, but  no change.
    2010-05-26T08:07:07+00:00
    Hey Larryed,
    Follow the recovery options that I previously listed above to recover your system, this will work, re-installing Windows 7 after is advised but may not be necessary if you want important files
    2010-12-02T08:50:30+00:00
    Did anyone ever figure out what caused this or what to do?  I am in the exact same boat as Jorge this week, and your description of symptoms sounds exactly like mine (no sound, no system restore, same error messages).  After trying every type of repair/restore, I'm ready to reinstall tomorrow.  I've got all my files backed up but I'm not looking forward to reinstalling all my programs.  Is it something with Revo?  I had just uninstalled a program too, and I'm always careful with what I delete, but it seems to be the common link with these complaints.
