0x80042302 on system restore..
2010-02-24T05:46:54+00:00
I am having some problems with my laptop Windows 7 Home Premium pc. It has been working fine until my mouse pad stopped working properly, I tried to do several times a system restore and it finally worked.
My Norton Antivirus expired and I removed it from my computer using Revo Uninstaller, the next time I booted my laptop, my wireless connection was off. I checked in Device Manager only to find out that there were 'warning' triangles in the network adapters and in all of my Universal Serial Bus Controllers. I fixed that by disabling everyone of them, and enabling them again.
I installed a Windows Update, and after the install my laptop started acting weird. I cant listen to my music since it doesnt let me open it, I cant open my pictures, I cant  watch videos on youtube; no sound comes out at all, and it Im not able to even open the properties in my computer. I tried to do a system restore but it gave me the error above (0x80042302) saying " A Volume Shadow Copy Service component encountered an unexpected error. Check the Application event log for more information."
I tried with an antivirus to see if it might have something to do, but it didnt find any.. Any ideas on what might be wrong?..
Thanks..
2013-06-29T21:11:04+00:00
Try checking all your services.search on start search  services.msc
I had this problem too,had no audio, the error code in system restore and couldn't connect to the Internet .all my services was disabled so I changed them all to automatic and it worked like a dream. Hope this helps.
47 additional answers
    2010-03-23T23:10:07+00:00
    Yes, im not able to listen to any audio either.. ill try to just reinstall windows 7...
    2010-03-25T17:07:11+00:00
    Hi Jorge C.,
    Have you reinstalled Windows 7?  Let us know if you are still having the same issue with System Restore.
    Dena
    2010-03-30T23:00:01+00:00
    I tried reinstalling the windows 7 (i have the upgrade version) but it stops at the beginning, saying that "Windows could not retrieve information about the disks on the computer", the problem has gotten worse files are getting corrupt and i cant even uninstall programs.. so yes, I am still having an issue with the System Restore.
    2010-04-02T14:09:46+00:00
    Hi Jorge C,
    Try completing the steps in this thread outlined by Dale Qiao.  Let us know if this works.
    Dena
