0x80042302 on system restore..
2010-02-24T05:46:54+00:00
I am having some problems with my laptop Windows 7 Home Premium pc. It has been working fine until my mouse pad stopped working properly, I tried to do several times a system restore and it finally worked.
My Norton Antivirus expired and I removed it from my computer using Revo Uninstaller, the next time I booted my laptop, my wireless connection was off. I checked in Device Manager only to find out that there were 'warning' triangles in the network adapters and in all of my Universal Serial Bus Controllers. I fixed that by disabling everyone of them, and enabling them again.
I installed a Windows Update, and after the install my laptop started acting weird. I cant listen to my music since it doesnt let me open it, I cant open my pictures, I cant  watch videos on youtube; no sound comes out at all, and it Im not able to even open the properties in my computer. I tried to do a system restore but it gave me the error above (0x80042302) saying " A Volume Shadow Copy Service component encountered an unexpected error. Check the Application event log for more information."
I tried with an antivirus to see if it might have something to do, but it didnt find any.. Any ideas on what might be wrong?..
Thanks..
2013-06-29T21:11:04+00:00
Try checking all your services.search on start search  services.msc
I had this problem too,had no audio, the error code in system restore and couldn't connect to the Internet .all my services was disabled so I changed them all to automatic and it worked like a dream. Hope this helps.
47 additional answers
    2015-10-03T10:30:46+00:00
    Search on my windows 10 isn't working as well. I have no way to find services.msc. Please help... :(
    2016-02-11T21:31:28+00:00
    I made the service " Volume Shadow Copy" to be running and set it on Automatic. The service System Restore did not appear on the list. Which means I still can not do a system restore.
    On my Win 7 Home Premier system, I also do not have System Restore Service, but another post mentioned Microsoft Software Shadow Copy Provider. I'm suspecting that's the new name for it.
    However, turning both Microsoft Software Shadow Copy Provider and Volume Shadow Copy to Start & Automatic, did not solve my problems. I still can't create a Restore Point.
    2016-05-01T10:49:35+00:00
    Imam nekih problema s moj laptop Windows 7 Home Premium kom. On je radio u redu dok je moj miš jastuk prestao ispravno raditi, pokušao sam napraviti nekoliko **** vraćanja sustava i to na kraju radila.
    Moj Norton Antivirus istekao i ja sam ga ukloniti s računala pomoću Revo Uninstaller, sljedeći put ću dignuti moj laptop, moj bežična veza nije bila isključena. Provjerio sam u Device Manager samo da bi saznali da je bilo "Upozorenje" trokuta u mrežnim adapterima i za sve moje Universal Serial Bus Controller. fiksna sam da onemogućavanjem svakoga od njih, te ih ponovno omogućiti.
    Instalirao sam na Windows Update, a nakon instalacije moj laptop počeo djelujući čudno. Ja ne mogu slušati moju glazbu, jer to ne dopusti mi da ga otvorite, ja ne mogu otvoriti moje slike, ja ne mogu gledati video na youtube; Ne čuje se zvuk izlazi na sve, a to im nije u mogućnosti da čak i otvoriti svojstva u mom računalu. Pokušala sam napraviti vraćanja sustava, ali to mi je dao pogrešku gore (0x80042302) govoreći: "volumenu Sjena Kopiraj usluga komponenta neočekivana pogreška. Provjerite dnevnik prijava event za više informacija."
    Pokušao sam s antivirusnim da li bi to moglo imati neke veze, ali to nije 'nađi prema bilo .. Bilo koji ideja o tome što bi moglo biti u redu? ..
    Hvala..
     windows 10 open too slowly or not at all open application when I click on the shortcut. Start button does not respond or with great delay. Google opens normal and what's normal. Everything worked properly until I uninstalled windows repair tools. When reset immediately proved a mistake too slowly opening at a time when the windows show a sign of welcome and greeting, and below that the circuit is constantly turning up to 10 minutes. when attempting to restore a PC in a few days back then, we show error 0x80042302. Thank you for your reply
    2016-05-17T23:14:53+00:00
    I too have been having the same problem with no results even though I set Volume Shadow Copy to automatic and set SPP Notifiction Service to automatic the problem persisted. So I went back to "Services" and discovered a service called "Microsoft Software Shadow Copy Provider", started it and set it to automatic and IT WORKS!! I can now backup my computer. I hope this helps at least one person out there.
    My laptop just went thru this yesterday, and I have yet to try and clear it up.
    But my major question is "WHY DID IT OCCUR??". Could it have anything to do with turning off some Microsoft AUTOMATIC updates?
    I had just read recently that Microsoft was sneaking there Windows 10 sales efforts into our computers without notifying use it was doing so. I was tired of that darn Win 10 pop-up window constantly appearing, AND I had read that there was a significantly LARGE file loaded on to everyones computer to prepare them for that upgrade. I felt that large file was slowing down my computer's booting, and sought to get rid of it and Microsoft's continuing effort to reload it (automatically).
    So that's my question? When I turned off one of those 'automatic updates' from them, did that precipitate this current problem that appears to be cured by turning everything back to 'automatic'??
