0x80042302 on system restore..
2010-02-24T05:46:54+00:00
I am having some problems with my laptop Windows 7 Home Premium pc. It has been working fine until my mouse pad stopped working properly, I tried to do several times a system restore and it finally worked.
My Norton Antivirus expired and I removed it from my computer using Revo Uninstaller, the next time I booted my laptop, my wireless connection was off. I checked in Device Manager only to find out that there were 'warning' triangles in the network adapters and in all of my Universal Serial Bus Controllers. I fixed that by disabling everyone of them, and enabling them again.
I installed a Windows Update, and after the install my laptop started acting weird. I cant listen to my music since it doesnt let me open it, I cant open my pictures, I cant  watch videos on youtube; no sound comes out at all, and it Im not able to even open the properties in my computer. I tried to do a system restore but it gave me the error above (0x80042302) saying " A Volume Shadow Copy Service component encountered an unexpected error. Check the Application event log for more information."
I tried with an antivirus to see if it might have something to do, but it didnt find any.. Any ideas on what might be wrong?..
Thanks..
2013-06-29T21:11:04+00:00
Try checking all your services.search on start search  services.msc
I had this problem too,had no audio, the error code in system restore and couldn't connect to the Internet .all my services was disabled so I changed them all to automatic and it worked like a dream. Hope this helps.
47 additional answers
    2014-11-21T04:30:23+00:00
    Thank you.I found it this way and reset it to Automatic, as it was indeed disabled. I will give it a whirl when I next need to do a system restore and let you know. I don't need to do one right now so there's no point in doing it for nothing...
    2015-01-18T07:58:36+00:00
    Thanks....
    Was solution to my problem...
    2015-03-14T00:49:14+00:00
    I am having the same problem I get the 0x80042302 shadow volume thing. But i dont have a restore point on this computer yet. Is there anything i can do. It will not let me back up anything.
    2015-06-03T11:01:38+00:00
    I had the same problem. Easy fix for me was to go to start menu search. Type 'msconfig' then when that opens go to 'services' tab and click 'enable all' as I believe they should be enabled. Mine had all been disabled. Had all the same errors with system restore and no sound or anything same as everyone else and this worked a treat. Hope this helps!
