Age of Empires II does not work with Vista or Windows 7
2009-11-24T16:43:16+00:00
I have been unable to get Age of Empires II to work on my laptop - first with Vista and now with Windows 7.
It installs OK and when you go to launch it the small graphic launch box comes up, then the screen goes phsychedelic before reverting back to normal and nothing more happens.
It is a Compaq Presario with a Mobile Intel R45 chipset.
Any advice?
Windows for home | Previous Windows versions | Gaming
2009-12-02T14:15:24+00:00
RusFry,
    If you were not able to get the game to run in this same PC with Vista or Windows 7, then it appears that there is a hardware conflict with this game.  I see that this game was for older systems and only supports 800x600 graphics.  You may want to turn your desktop resolution down to 800x600 with 256 colors, then launch the game.  If this doesn't help then you may want to install DirectX 9 and see if that helps.
60 additional answers
    2010-06-02T12:21:58+00:00
    Hello DarEDiomedes,
    I test your solution, but nothing work. I have Kaspersky as anti-virus, disabled the protection for AoE II, do the same thing for the firewall. And i cannot launch multiplayers game in LAN. i tink i will install XP in an other partition ... for only one game ... The worst is for the microsoft developers it will be easy to create a little patch ...
    Bye
    2010-06-05T09:47:53+00:00
    my problem is starting a game that others can see, or joinging a game
    Im currently running windows 7 ultimate, and cannot get a game that others can see.
    thats the same with my brother who is on vista.
    my 3rd brother still running XP managed to start a game that we can see with the help of google (<3)
    but we cannot join it.
    its saying timed out Monte Giles said.
    but i still cant figure it out.
    any help will be fantastic :D
    thanks!
    2010-07-16T20:57:40+00:00
    Hi
    Just upgraded to Windows7, game colours are not to bad when you run the game in XP pack3 mode. Found by - right click shortcut/properties/compatibility/check compatibility mode. Most colours comeright and screen resolution is good.
    2010-07-16T20:59:49+00:00
    Graphics problems.
    Hi
    Found by - right click shortcut/properties/compatibility/check compatibility mode. Most colours come right and screen resolution is good.
