Wireless Xbox 360 Controller Receiver For Windows Not Detecting/Working
2010-01-22T04:56:33+00:00
I purchased the Xbox 360 Wireless Controller Receiver For Windows and it is not working. I am running Windows 7 64-bit on a Sony Vaio VGN-NW225F laptop. I navigated to the correct place on Microsoft's website and downloaded the appropriate Windows 7 64-bit software for my receiver. It was an exe file and it installed correctly, or at least it said it did. This leads me to believe it is software and not an actual driver, because when I plug my receiver in, it lights up but comes up as "Installing device driver software..." then it says "Installation failed..." and registers the device as an unknown device.
I still press the button to sync it, and then I press the sync button on my controller, my controller recognizes the receiver and connects to it (both devices stop trying to sync) but as the receiver is not recognized by my computer, it is not communicating that a controller is connected.
This is frustrating because there is no documentation for honest support. Going to the support page it lists several things "Windows, Hardware, Audio" etc, but under NONE of these categories is this product, leading me to believe Microsoft simply doesn't give a ____ about me or my problem. Then when I go to support and try and type in my PID (product identification number) it says there is a problem with the number.
2010-02-06T21:37:28+00:00
i had the exact same problem, i even bought a new controller to no avail. i eventually found the solutionon another forum and now even my old controllers work. after two weeks of searching i can finally breath a sigh of relief.
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Windows Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
107 additional answers
    2011-11-25T21:29:22+00:00
    thank you so much, this worked perfectly for me
    2011-12-06T23:14:28+00:00
    Thanks for this. Saved me hours of messing about.
    2011-12-14T13:09:48+00:00
    It looks like the device you bought isn't a genuine Microsoft product, I fell for this trap myself as it's very hard to distinguish the real product from a fake.
    Because of the low price and because of the fact that after these steps it does work, I chose to report the device with Microsoft, but I haven't replaced it with a new one as I couldn't find a retail store in The Netherlands that sells one.
    To get your device to work, follow the steps mentioned by cyberfoxx, I actually wrote a blogpost about this with just a little more details.
    2012-02-11T19:32:11+00:00
    thank you thank you thank you!!!!!!!!!!!!!!!!!!!!!!!!!
