Wireless Xbox 360 Controller Receiver For Windows Not Detecting/Working
2010-01-22T04:56:33+00:00
I purchased the Xbox 360 Wireless Controller Receiver For Windows and it is not working. I am running Windows 7 64-bit on a Sony Vaio VGN-NW225F laptop. I navigated to the correct place on Microsoft's website and downloaded the appropriate Windows 7 64-bit software for my receiver. It was an exe file and it installed correctly, or at least it said it did. This leads me to believe it is software and not an actual driver, because when I plug my receiver in, it lights up but comes up as "Installing device driver software..." then it says "Installation failed..." and registers the device as an unknown device.
I still press the button to sync it, and then I press the sync button on my controller, my controller recognizes the receiver and connects to it (both devices stop trying to sync) but as the receiver is not recognized by my computer, it is not communicating that a controller is connected.
This is frustrating because there is no documentation for honest support. Going to the support page it lists several things "Windows, Hardware, Audio" etc, but under NONE of these categories is this product, leading me to believe Microsoft simply doesn't give a ____ about me or my problem. Then when I go to support and try and type in my PID (product identification number) it says there is a problem with the number.
2010-02-06T21:37:28+00:00
i had the exact same problem, i even bought a new controller to no avail. i eventually found the solutionon another forum and now even my old controllers work. after two weeks of searching i can finally breath a sigh of relief.
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Windows Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
107 additional answers
    2011-08-17T23:57:37+00:00
    everything went well according to the steps but still no luck. I got the device manager to recognize the receiver but they just keep searching for each other!
    2011-08-18T00:06:05+00:00
    wait never mind I tried my other 360 controller and that worked I'll just need to figure out the first one since the working one is defective but thanx like **** man I didn't think this pc thing was gonna work for a while there you sir are money
    2011-09-18T23:07:47+00:00
    thanks man that worked great it was frustrating the **** out of me :)
    2011-09-30T12:07:16+00:00
    Thank you so much, this worked for me. I was having the same problem and you solved it. Thank you very very much!
