Wireless Xbox 360 Controller Receiver For Windows Not Detecting/Working
2010-01-22T04:56:33+00:00
I purchased the Xbox 360 Wireless Controller Receiver For Windows and it is not working. I am running Windows 7 64-bit on a Sony Vaio VGN-NW225F laptop. I navigated to the correct place on Microsoft's website and downloaded the appropriate Windows 7 64-bit software for my receiver. It was an exe file and it installed correctly, or at least it said it did. This leads me to believe it is software and not an actual driver, because when I plug my receiver in, it lights up but comes up as "Installing device driver software..." then it says "Installation failed..." and registers the device as an unknown device.
I still press the button to sync it, and then I press the sync button on my controller, my controller recognizes the receiver and connects to it (both devices stop trying to sync) but as the receiver is not recognized by my computer, it is not communicating that a controller is connected.
This is frustrating because there is no documentation for honest support. Going to the support page it lists several things "Windows, Hardware, Audio" etc, but under NONE of these categories is this product, leading me to believe Microsoft simply doesn't give a ____ about me or my problem. Then when I go to support and try and type in my PID (product identification number) it says there is a problem with the number.
2010-02-06T21:37:28+00:00
i had the exact same problem, i even bought a new controller to no avail. i eventually found the solutionon another forum and now even my old controllers work. after two weeks of searching i can finally breath a sigh of relief.
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Windows Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
107 additional answers
    2010-03-13T16:06:53+00:00
    Good to know that, you have resolved the issue.
    For any further assistance, please feel free to contact Microsoft Answers.
    You have a good day.
    Thanks and regards,
     Fouzan – Microsoft support.
     Visit our Microsoft Answers Feedback Forum
     http://social.answers.microsoft.com/Forums/en-%20US/answersfeedback/threads and let
     us know what you think.
    2010-03-24T19:01:47+00:00
    I'm having a similar problem, though when I go through the order of operations listed above, it ends with a Code 10 (This device cannot start) error. I called Xbox support and they implied that I purchased or chose an inferior piece of equipment, even though I got it off of Amazon.
    Here's what has happened so far:
    I opened the package. It contained the hardware receiver and a CD/mini disk. I put the mini disk into my optical drive. I get an alert saying that this software is incompatible with my version of Windows. I have Windows 7. There's a clear as day graphic on the packaging that says "Compatible with Windows 7" but the setup utility says otherwise. So I hunted around for drivers and ultimatley found the updated driver on the Microsoft website. Downloaded it, installed it, restarted my computer. I plugged the receiver into a USB port, followed the steps from above. I choose Xbox 360 Controller for Windows Version: 2.1.0.134 [8/13/2009] as the desired driver. I hit Next. I get an update Driver Warning telling me that the Driver may not be compatible, and whether I want to continue or not. I hit yes. I get a "Installing Driver" progress bar which abruptly ends and is followed up by a Code 10.
    Help, please.
    2010-05-18T21:12:20+00:00
    i am doing this, but once i get to "let me pick form a list of device drivers on my computer" there is no windows common controller for windows class, it ends with Windows SlideShow. any ideas? i really want to get this receiver connected to my controller, thanks
    2010-07-07T07:25:49+00:00
    maxinator just choose show all and look under microsoft. i got it installed this way. though it still doesnt detect my controller..
