Error 1402: could not open key: unknow\components\3178400169C22D11A9790006794C4E25\7D2F387510089040102000060BECB6AB
2009-10-07T06:14:56+00:00
I already checked on the persissions, i am logged on as administartor, UAC turned off.
There was a bad uninstall of the product, had to run "Windows Installer Cleanup" because was receiving message "already installed" at setup.
Now i have this Error 1402. Something else i need to clean up before reinstallation?
Thank you for any advice.
Jean-Luc
2009-10-13T01:46:28+00:00
RESOLVED!
(Error 1402 while attempting to re-install Office 2003 on Vista Home Professional)
This was resolved for me by running the "Fix-It" that resets registry security settings.  It is at the following knowledgebase article:
http://support.microsoft.com/kb/313222
Then re-run the install
Thank you to the folks at the following forum/post
http://omgili.com/jmp/.0rSU5LtMgwKlLvLcgIskPccX\_Otxaq47tlOHhXkGRb9DAq3tpx1C4gh00DZZkwslO.hn8FUUZ6pJCwCoNtBn12lpf\_8OAH6BolXoJuTLbCHiTcfU\_6jli4B1kprrvOCwEcK4Gjdz5IvN3UiylfPOFgVs1w9TIbZNZLV.aWzM3N\_YsKkJIKHJTprxix8tG5wBpocyMRkNgo\_RuSfQ.umQF\_dt5CcWAXASWe6ClVIyU4-
I tried to 'reply' to their post but their site crashed in the attempt.
44 additional answers
    2010-01-08T08:59:21+00:00
    All,
    I am also attempting to find a solution to this problem. I am running Windows 7 and am trying to do an installation of a purchased copy of Office Professional 2007.  I tried the msconfig method listed above, rebooted, and still had the same error at the same time during the installation.
    Thank you for your help.
    Kind regards,
    Bob Lee
  2. Deleted
    2010-02-08T07:52:04+00:00
    i have the error 1402 about some registry key preventing me from installing office 2007 i am using windows 7 x64 is there a solution?
    You're a load in my pants Al.
    2010-02-08T07:53:03+00:00
    Error 1402 setup cannot open the registry key and then a lot of wierd text follows...
