Error 1402: could not open key: unknow\components\3178400169C22D11A9790006794C4E25\7D2F387510089040102000060BECB6AB
2009-10-07T06:14:56+00:00
I already checked on the persissions, i am logged on as administartor, UAC turned off.
There was a bad uninstall of the product, had to run "Windows Installer Cleanup" because was receiving message "already installed" at setup.
Now i have this Error 1402. Something else i need to clean up before reinstallation?
Thank you for any advice.
Jean-Luc
2009-10-13T01:46:28+00:00
RESOLVED!
(Error 1402 while attempting to re-install Office 2003 on Vista Home Professional)
This was resolved for me by running the "Fix-It" that resets registry security settings.  It is at the following knowledgebase article:
http://support.microsoft.com/kb/313222
Then re-run the install
Thank you to the folks at the following forum/post
http://omgili.com/jmp/.0rSU5LtMgwKlLvLcgIskPccX\_Otxaq47tlOHhXkGRb9DAq3tpx1C4gh00DZZkwslO.hn8FUUZ6pJCwCoNtBn12lpf\_8OAH6BolXoJuTLbCHiTcfU\_6jli4B1kprrvOCwEcK4Gjdz5IvN3UiylfPOFgVs1w9TIbZNZLV.aWzM3N\_YsKkJIKHJTprxix8tG5wBpocyMRkNgo\_RuSfQ.umQF\_dt5CcWAXASWe6ClVIyU4-
I tried to 'reply' to their post but their site crashed in the attempt.
44 additional answers
    2012-06-21T11:31:27+00:00
    The 1402 error is a problem caused by the Office installation being unable to open and save a certain registry key on your PC.http://microsoft-support-squad.blogspot.in/2012/04/fix-microsoft-office-1402-error.html
    2012-07-03T17:51:16+00:00
    Thank you so much for the post, I was having a hard time to install the Visual Studio 2010. Always getting the error "Error 1402: could not open key: unknow\components ..." The "secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose" command line worked for me like a charm. I just have VS2010 installed.
    My hat off and thumbs up.
    2012-10-18T16:57:44+00:00
    Hi Paul ! I tried to follow the steps in kb3132222 page you said but I could not found the right answer to resolve the issue. What app or patch did you ran to fix it ? I couldn't find any fixit or other app to reset the registry security settings... I would really appreciate your help on this !!!!!
    Thanks !
    2012-10-24T14:33:02+00:00
    Run:
    as Administrator in command prompt.  It works, but does not if not ran from Administrator.  (Literally, right click, "Run as Administrator") then execute command.
    Cheers.
