Need Xbox 360 Chatpad driver
2008-12-29T11:52:11+00:00
one year ago i buy a Xbox 360 Controller Made by Microsoft Corporation and a Chatpad for it. on the box was info about use for Windows-based PCs but until now no driver... so i am here to ask for some help. For now i can turn the backlight on sending
ctrl 0x41 0x0 0x1f 0x02 # Init (without this, no led wil work)
ctrl 0x41 0x0 0x8 0x02 # capslock
ctrl 0x41 0x0 0x9 0x02 # square
ctrl 0x41 0x0 0xa 0x02 # circle
ctrl 0x41 0x0 0xb 0x02 # people
ctrl 0x41 0x0 0xc 0x02 # backlight
ctrl 0x41 0x0 0x11 0x02 # capslock
ctrl 0x41 0x0 0x12 0x02 # square
ctrl 0x41 0x0 0x13 0x02 # square and capslock
ctrl 0x41 0x0 0x14 0x02 # circle
ctrl 0x41 0x0 0x15 0x02 # capslock and circle
ctrl 0x41 0x0 0x16 0x02 # circle, square
ctrl 0x41 0x0 0x17 0x02 # circle, square, capslock
ctrl 0x41 0x0 0x1b 0x02 # makes led go on on keypress
ctrl 0x41 0x0 0x1e 0x02 # Init2 >>> Ep6: [5] { 0xf0, 0x03, 0x00, 0x01, 0x01 }
i also have acess to USB protocol analyzer (but it is not mine... sorry) to have the info that travell between the controller and the Xbox
also we can recive one key press but after it is dead.... and i dont know why... a lot of people are working on it but microsoft made it so at leas you can help us to try make a driver...
2nd byte flags:
shift/capslock = 0x01
square = 0x02
circle = 0x04
people = 0x08
3rd byte keycodes:
1 = 0x17
2 = 0x16
3 = 0x15
4 = 0x14
5 = 0x13
6 = 0x12
7 = 0x11
8 = 0x67
9 = 0x66
0 = 0x65
q = 0x27
w = 0x26
e = 0x25
r = 0x24
t = 0x23
y = 0x22
u = 0x21
i = 0x76
o = 0x75
p = 0x64
Windows for home | Previous Windows versions | Gaming
    2017-08-31T20:30:29+00:00
    Почему нету ответа ...
    Я купил chatpad для windows 10 но он не работает ... (((((((((
    Помогите
