Microsoft Virtual Wifi Miniport Adapter driver problem (Error code 31)
2010-02-09T04:22:57+00:00
My Microsoft Virtual Miniport Adapter is not up to date (It tells me this when I try to connect wirelessly to something and also when I view it in Device Manager, it has a caution sign next to it.) and when I went to install it in Windows update, it failed several times to install so I gave up. Now I keep going to update the driver in device manager but it keeps saying it is up to date, even though it's not! I uninstalled the driver sofware completely and restarted my PC in hopes that it would install new driver software, but it didn't, it just reinstalled the old driver software and it still says the driver software is old and not functioning properly.
By the way I am running WINDOWS 7.
PLEASE HELP! I can't even connect to the internet!
2011-03-01T16:27:10+00:00
well you cant uninstall it its a part of windows but you can disable it, at first right clicking and click disable on device manger,but i found a command that disables it to.at first i though it was  the same as above but it actually disables the service and its gone wow first stop it in cmd as admin "netsh wlan stop hostednetwork" no quotes. then stop the service by  typing "netsh wlan set hostednetwork mode=disallow" also no quotes IT WORKS WOW TRY IT!!!
2011-03-21T09:11:55+00:00
Many Many Thanks Tyler
This worked straight away:
2010-02-10T02:57:28+00:00
Hi BlackOut0189,
The Microsoft virtual wifi miniport adapter is a new feature in Windows 7, Wireless Hosted Network:
About the Wireless Hosted Network
This device is just a virtual device and it should not affect connecting the wireless network with the physical wireless adapter.
Hence, I’d suggest you to uninstall and re-install only the wireless network adapter drivers from Device manager and check if that fixes the issue.
Note: Before uninstalling the drivers from the device manager, make sure you have a backup of the installation files.
It’s a good idea to create a restore point before uninstalling the drivers. A restore point is a representation of a stored state of your computer's system files. You can use a restore point to restore your computer's system files to an earlier point in time. Restore points are automatically created by System Restore weekly and when System Restore detects the beginning of a change to your computer, such as when you install a program or a driver.
Refer the following Microsoft article for more information on creating a restore point:
Create a restore point
**http://windows.microsoft.com/en-US/windows7/Create-a-restore-point**
Visit the manufacturer’s website, download the latest wireless drivers and save it on your hard disk.
To uninstall the wireless connection from Device Manager,
  1. Click Start, type Device Manager in the Start search box and hit Enter.
  2. Locate Network adapters and expand the same.
  3. Select the wireless connection, right-click and select Uninstall.
  4. Restart the computer, if prompted.
Drivers should get installed automatically after restarting the computer.
Now, you may install the latest wireless drivers and check if that fixes the issue.
Hope this helps.
Gokul - Microsoft Support
[If this post was helpful, please click the "Vote as Helpful" (green triangle) button. If it helps in resolving your issue, click "Propose As Answer" or "Mark as Answer" button. By proposing/marking a post as Answered, or Helpful you help others find the answer faster.]
42 additional answers
    2013-01-09T14:41:50+00:00
    Brilliant post ! thanks a lot
    2013-05-02T23:07:22+00:00
    Hi
    I want to ask you one thing. Lately i uninstalled Wi-fi miniporter adapter from my computer and now i need ir back. Is it located somewhere in my computer or should i download it? If yes then where?.
