Attached network drive does not remember credentials so have to log in every time I boot up the machine even when I click the button to remember details.
2009-11-25T20:00:29+00:00
Using windows 7 I have a NAS drive that I need to manually log into everytime my machine us started up - I want it to remember the login details and do it automatically when the machine starts as my wife also uses it and I want the auto backup to run.
2015-06-30T06:18:38+00:00
Use credential manager in Windows 7 to remember the username and password for your NAS Drive if it doesnt remember it automatically.
Go to Start / Control Panel / User Accounts and Family Safety / Credential Manager
On the right hand side, right below where it says "Windows Credentials" Select "Add a Windows Credential".
Enter your NAS' Server name in the first box.
User Name in the second box and your password for the server in the third box.
2009-11-26T19:34:40+00:00
Hi red_shift,
Welcome to Microsoft Answers!
I would suggest you to check the options in settings.
If it is a mapped network drive, Please follow the steps below:
1.      Open Computer by clicking the Start button, and then clicking Computer.
2.      Click Map network drive.
3.      In the Drive list, click a drive letter.
You can choose any available letter.
4.      In the Folder box, type the path of the folder or computer, or click Browse to find the folder or computer.
To connect every time you log on to your computer, select the Reconnect at logon check box.
5.      Click Finish.
Your computer is now connected, or mapped, to the network drive.
For further information, visit the below mentioned link:
http://windows.microsoft.com/en-US/windows7/Create-a-shortcut-to-map-a-network-drive
Hope this information helped!
Thanks and regards
 Fouzan – Microsoft support
 Visit our Microsoft Answers Feedback Forum
 http://social.answers.microsoft.com/Forums/en- US/answersfeedback/threads/ and let
 us know what you think.
49 additional answers
    2010-04-21T15:13:24+00:00
    That doesn't work either. But nice try.
    2010-04-21T15:39:16+00:00
    I used this technique on about a dozen computers last week.. Make sure you are up to date with all windows patches, disable your anti-virus and firewall and re-do all you did and do not select "use different username" in the drive mapping dialog. Tell me exactly at what point it doesn't work. I don't have time to post detailed instructions but that is the general way to do it. Also what OS are you using?
    2010-04-29T18:16:52+00:00
    I'm new to mapping
    i have a 16 bay DAS.. im trying to map the drives but ive ran out of drive letters? how the heck do we map all our drives? i have at least 13 that NEED to be mapped! and when i started mapping it said i only had 5 to choose from? no i have ZERO to choose from and have 7 more drives i need mapped!
    Any help would be appreciated!
