Attached network drive does not remember credentials so have to log in every time I boot up the machine even when I click the button to remember details.
2009-11-25T20:00:29+00:00
Using windows 7 I have a NAS drive that I need to manually log into everytime my machine us started up - I want it to remember the login details and do it automatically when the machine starts as my wife also uses it and I want the auto backup to run.
2015-06-30T06:18:38+00:00
Use credential manager in Windows 7 to remember the username and password for your NAS Drive if it doesnt remember it automatically.
Go to Start / Control Panel / User Accounts and Family Safety / Credential Manager
On the right hand side, right below where it says "Windows Credentials" Select "Add a Windows Credential".
Enter your NAS' Server name in the first box.
User Name in the second box and your password for the server in the third box.
2009-11-26T19:34:40+00:00
Hi red_shift,
Welcome to Microsoft Answers!
I would suggest you to check the options in settings.
If it is a mapped network drive, Please follow the steps below:
1.      Open Computer by clicking the Start button, and then clicking Computer.
2.      Click Map network drive.
3.      In the Drive list, click a drive letter.
You can choose any available letter.
4.      In the Folder box, type the path of the folder or computer, or click Browse to find the folder or computer.
To connect every time you log on to your computer, select the Reconnect at logon check box.
5.      Click Finish.
Your computer is now connected, or mapped, to the network drive.
For further information, visit the below mentioned link:
http://windows.microsoft.com/en-US/windows7/Create-a-shortcut-to-map-a-network-drive
Hope this information helped!
Thanks and regards
 Fouzan – Microsoft support
 Visit our Microsoft Answers Feedback Forum
 http://social.answers.microsoft.com/Forums/en- US/answersfeedback/threads/ and let
 us know what you think.
49 additional answers
    2012-01-19T09:04:40+00:00
    Credentials for network drives are only remembered until the end of the user session. This means that you will be prompted again for credentials after a log off/login, sleep or restart operation. It is possible to save credentials in a sort of "credentials vault" starting in Windows XP.
    In XP: To configure this option, you go in the control panel, and then in the section for user configuration (where you set password, profile pictures etc.) you select the user you wish to configure the vault for. On the left side, there should be a "manage your network passwords" link. This is where you will add the server along with the credentials. Important note: Disconnect and remap whatever mapped drive you have made. When you re-map do NOT click the "use different username" link, simply press "Finish".
    Vista and 7: The option is also inside control panel's user section but it's now called "Credential Manager". Add a "Windows credential". Important note: Disconnect and remap whatever mapped drive you have made. When you re-map do NOT click the "use different username" link, simply press "Finish".
    For Windows 2000 you will have to have the same username and password on both the NAS/Server and on your PC because there is no credentials manager.
    I agree with everyone's frustrations; this is one of the unpolished edges of Windows.. Keep in mind though, it becomes hard to make everything perfect for every user scenario when there are requirements from so many stakeholders.
    -Adam
    In XP: I made those indicated, but credentials disappear again, at restart, from [Stored User names and Passwords]. I made the same on the built-in account Administrator and the credential does not disappear.  It seems that the credentials (username and password) are deleted at windows logoff or logon only for my account (account type: computer administrator). I do not know how to solve the problem.
    2012-02-06T20:46:51+00:00
    There's a subtle 'error' windows (i'm on win 7) introduces when using credentials. It will set your username to "USER-PC/device username" when really all your device wants is "device username". I had to go into credentials manager and remove the "USER-PC" part, and works fine.
    Thank you for this tip.  I think that was the problem I was having also.  I will not know for sure until I have to reboot again, but I am pretty sure this will solve the problem.  That seems like a bug to me.  It should not add the "USER-PC" part.
    2012-03-10T07:51:48+00:00
    -Adam
    HI ,
    I have following all your step above in window XP, everything work when i access to my network share resource no need type username and password credential, but when i restart the computer, every thing that we have set in Manage My Network username and password gone. If your Adminstrator can't store, the other user can't.
    Do you have any solution about this
