Attached network drive does not remember credentials so have to log in every time I boot up the machine even when I click the button to remember details.
2009-11-25T20:00:29+00:00
Using windows 7 I have a NAS drive that I need to manually log into everytime my machine us started up - I want it to remember the login details and do it automatically when the machine starts as my wife also uses it and I want the auto backup to run.
2015-06-30T06:18:38+00:00
Use credential manager in Windows 7 to remember the username and password for your NAS Drive if it doesnt remember it automatically.
Go to Start / Control Panel / User Accounts and Family Safety / Credential Manager
On the right hand side, right below where it says "Windows Credentials" Select "Add a Windows Credential".
Enter your NAS' Server name in the first box.
User Name in the second box and your password for the server in the third box.
2009-11-26T19:34:40+00:00
Hi red_shift,
Welcome to Microsoft Answers!
I would suggest you to check the options in settings.
If it is a mapped network drive, Please follow the steps below:
1.      Open Computer by clicking the Start button, and then clicking Computer.
2.      Click Map network drive.
3.      In the Drive list, click a drive letter.
You can choose any available letter.
4.      In the Folder box, type the path of the folder or computer, or click Browse to find the folder or computer.
To connect every time you log on to your computer, select the Reconnect at logon check box.
5.      Click Finish.
Your computer is now connected, or mapped, to the network drive.
For further information, visit the below mentioned link:
http://windows.microsoft.com/en-US/windows7/Create-a-shortcut-to-map-a-network-drive
Hope this information helped!
Thanks and regards
 Fouzan – Microsoft support
 Visit our Microsoft Answers Feedback Forum
 http://social.answers.microsoft.com/Forums/en- US/answersfeedback/threads/ and let
 us know what you think.
49 additional answers
    2011-09-19T03:12:33+00:00
    As the poster just above (swordsandplows) I too was having problems logging to a Synology NAS. After reading all the comments I tried the map network drive and setting the credentials in credential manager (windows 7) but it was still failing. After re-checking everything, I noticed that the name of my user on my NAS had a the first letter capitalised, which is why the logging was failing.
    I just thought I'd mention it in case someone else runs into this issue.
    2011-10-22T00:42:13+00:00
    Thx very much !! It's really helpful,I tired many solutions but doesn't work .I am running win7 pro x64
    2012-01-19T04:05:02+00:00
    I have the exact issue as CPatterson78 with the one Windows Vista Home Premium computer in our home (my wife's).  The XP machines connect without asking for login, just like my wonderful Mac (of course).  But my wife is ready to throw her Vista machine out the window, especially having to log in every time she wants to access the local shared files on the Buffalo NAS.
    It seems like having the Windows logon credential option disabled (in Vista Home) is the main block to using adm.adum's solution.  I know this is an old post now, but maybe someone has found a solution for those of stuck with a Vista machine that probably can't even upgrade to Windows 7.
