What is Jucheck.exe; keep it or remove?
2010-04-02T13:36:31+00:00
Hello.  Sorry if this is an old question, but I can’t find a good answer to this yet.
My computer is a couple weeks old, I have Windows 7 Home Premium, and when I turned it on today I got a request to allow “jucheck.exe” to run.  It didn’t really give any information on the window, so I told it “No”.  After some research, I’ve seen people say that if the file is in Program Files then it is fine, but if it is in Windows\System 32 then it is dangerous.  The request for it to run said that it was in Windows\System 32 and I searched for it and Jucheck.exe showed up in both Program Files and Windows\System 32; both identical, by the looks of them, same size (422kb / 432,128 bytes) , dates, etc.  I also found it in C:\Windows\SysWOW64, though it was a different size (377 KB / 386,872 bytes).  I scanned the files with McAfee and it came back clean, so I don’t really know what to think about it.
So, should I be concerned?  Should I get rid of it?  And how might I go about it?
Thanks in advance for any advice.
LemP 74,970 Reputation points Volunteer Moderator
2014-07-07T21:05:51+00:00
@elfisho --
jucheck.exe is the name of the program that checks for Java updates.  Unfortunately, however, malware can also use the same name.
On my Win 7 Pro x64 system, I have only one instance of jucheck.exe, and it is in
    C:\Program Files (x86)\Common Files\Java\Java Update\jucheck.exe
It's a different size than yours -- 499 KB (511,872 bytes) -- and probably a newer version, if you haven't let Java update in a while (mine is version 2.1.60.19; you can right-click on your file, select Properties and then the "Details" tab).
You've copied an old response from 2011, so I don't know if you have scanned the files you found.  If you have scanned them with an up to date antivirus, then you're probably OK.
If you're concerned, submit the file(s) to https://www.virustotal.com/ where they will be checked automatically (in real time) by a large collection of antimalware tools.
If I were you, I'd do the following:
  1. Go to Control Panel > Programs and Features and uninstall anything that starts with "Java" (the current version is Java 7 Update 60)
  2. Go to http://java.com/en/download/uninstallapplet.jsp and click the "Agree and Continue" button
  3. If any older versions of Java are found, they will be uninstalled.  Then download the installer stub for the current version.
  4. Before you install the current version, check in the locations where you previously had found jucheck.exe and if any of the files are still there, delete them.
  5. Run the file you downloaded; this will download the full installer and then start the installation process.  Be sure to UNCHECK the boxes that will otherwise install the Ask Toolbar.
2010-04-02T13:51:21+00:00
Hello PyreSR – Welcome to Microsoft Answers Community.
The Jucheck.exe is part of Sun® microsystems components, it is
in fact the Sun® Java UpdateChecker Module. If any antivirus
program is complaining about the file, please paste the virus name.
As far as known, it shall not be a virus.
I hope you find this information useful and if you need any further assistance,
please feel free to contact me and let me know.
I hope this information was helpful…
Have a nice day…
Best regards,
Fisnik
Itknowledge24.com
2016-10-09T02:36:24+00:00
Jucheck
I have had many PCs, Laptops, etc.  Until recently, about 6-8 months ago, I get this jcheck.exe pop up, telling Java update is available.  There a number of easy things you have to do to safeguard your machine, what I did/do are:
  1. I go the source, Oracle (who make Java), and see if there is indeed an update available - at least 5 times during my jucheck.exe plague.
2.  Only recently this has begun to appear, at least everu 4-5 days; asked myself, Java have never released so many updates.
3.  If there is indeed an update available, then download from the main, Sun/Oracle website, there are two useful sites, https://www.oracle.com/index.html and https://search.oracle.com.  You need only check these once or twice, and will find jucheck.exe is perhaps harmful; I am not an expert and for me, it is better this way.
Conclusion.  It is a mystery to me why common, highly rated safety software, have not yet picked it up?? either way, safe or not - simply, they should send an email to all subscribers, who pay a lot of money, telling us whether it is safe or harmful.
I hope this helps, takes minutes, could have you a lot in time, money and aggravation; IO found after about 10 checks that go update about once a month, directly at above sites.
Good Luck
Prakash
117 additional answers
    2013-03-19T06:03:39+00:00
    Hi Erica,
    I followed your suggestion and went to my programs but only saw Java updates, 13 and 15(64 bit) and one that said Java SE development kit 7 update 15 (64 bit) not the update 38 as stated. Any suggestions?
    2013-03-21T01:16:20+00:00
    For what it's worth, it bears repeating.
    Java used to be Sun's. Sun is no more. (Thank you Microsoft for that.) Unfortunately, it's hard to update certificates once they leave the factory.
    Java now belongs to Oracle. (Thank you Billy Gates and company for that.)
    So the certificates that Java uses to update itself should say they are from Oracle, but they may say they are from sun. Which helps you not at all, because malware will try to tell you it is from somewhere you should trust. I mean someplace that wants you to trust them.
    A company that sells software based on this kind of web-of-trust should not be trusted. (I'm not looking at Oracle or Sun, now, Microsoft, am I? Thank you Billy and Nate and company, for the pack of malware you enable.)
    The proper solution is a bitter pill for dedicated MSWindows users: Install Linux. Learn to use it.
    Most people who come here won't like that idea. Neither will the culprit that runs this "knowledge base". So this post will be deleted pretty darn quick.
    The next best solution was pointed out somewhere back a ways. I'll summarize it.
    Go to your control panel. (I know this is scary, but just do it.)
    Click "Windows Defender" and scan your machine. (This takes a while. Go get a cup of cocoa. Read the newspaper or a book.) If you don't feel comfortable with Microsoft's scanners, use Norton/Symantec or McAffee to do the scan. And ask yourself why you use an operating system made by people you don't trust.
    Now click Java in your control pane. Disable updates. It will complain. It must complain. Since Java 7 (Oracle's spawn) Java has been a mess, and it must beg you to allow it to keep trying to fix itself. Which it can't, since it is now owned by a company that doesn't want it fixed. Go by your instincts here. Maybe even delete java entirely.
    If you keep Java, go to Oracle's web site and download the update software from them, directly. (This is also fraught with peril, but it's a bit safer than relying in jucheck.exe.) Run the updater directly.
    Why the confusion about jucheck.exe? Well, there is a legitimate one, but the malware authors like to do the sheep-in-wolf's-clothing thing and call their junk you want to trust, like jucheck.exe.
    If you know to tell where their code is running from, "Program Files" is where it should be running from. And if malware gets in there, you already have much bigger problems than you wanted.
    If it's running from anywhere else, use your task menu to kill it outright, then go delete it. If you can. Malware likes to move around and hide. And you'll have to make system files visible, to find it, because the malware will be saying it's a system file.
    Java used to be good technology. Now it's no better than Silverlight.
    The safest way to run MSWindows is in a virtual machine.
    Use the virtual machine software to make a safe system image and copy that every time you start up. Then you save out the files you need and erase the entire system when you are done. And you keep a backup of your safe system image, just in case. Several backups, including the one fresh from the factory.
    If you don't want to do that, Linux (including Android) is still safe for a while.
