System Recovery Failed Error "0xc0000022"
2010-08-13T16:47:37+00:00
original title: HAVING ERROR "0xc0000022" due to which recovery was not successful.plz help
i did the recovery procedure on my laptop but got msg..
due to erroe "0xc0000022" recovery was not successful
2015-04-02T16:54:34+00:00
Hello Resalat,
Thank you for the response.
I appreciate your time.
As you mentioned that Windows is slow, I would suggest you to run this Microsoft fixit and check if it helps.
Refer:
Fix Windows system performance problems on slow Windows computers
https://support.microsoft.com/en-us/mats/slow_windows_performance
Please also run Microsoft safety scanner to check for any virus or malware which may be causing the issue.
Refer:
http://www.microsoft.com/security/scanner/en-us/default.aspx
Note: Any data files that are infected may only be cleaned by deleting the file entirely, which means there is a potential for data loss.
I hope this information helps.
Thank you
52 additional answers
    2014-01-13T14:29:43+00:00
    I have done the scannow process and Window Resource Protection did not find any integrity violations
    What would the next step be??
    Alan ******@Hotmail.co.uk
    2014-02-09T12:59:24+00:00
    Ok, I did that, and it came up all ok... hmmm..... Oh Well, there's always reset Internet Explorer, and start over, I think I'll  try it like this for a while, as it is running ok, unless problem gets worse, Thank you all for your help.... End problem... I may be back,,, Happy Valentines day...
    2014-10-12T19:27:31+00:00
    I have changed the black cartridge in my cannon printer now unable to print photos
    fault printer not responding.
    2014-10-20T10:18:35+00:00
    Hi Debleena
    I was forced to do a system restore as my windows internet explorer does not start up now after the latest windows updates.
    tried system restore and got following message.
    System restoration could not be done Computer file and programs has not been changed, information A: unknown error occurred during system restore (0xc0000220).
    So i have carried out sfc /scannow as you suggested when helping others, that has corrected the problem, but internet explorer does still not work any suggestions would be appreciated.
    Kind Regards
    Jim
