System Recovery Failed Error "0xc0000022"
2010-08-13T16:47:37+00:00
original title: HAVING ERROR "0xc0000022" due to which recovery was not successful.plz help
i did the recovery procedure on my laptop but got msg..
due to erroe "0xc0000022" recovery was not successful
2015-04-02T16:54:34+00:00
Hello Resalat,
Thank you for the response.
I appreciate your time.
As you mentioned that Windows is slow, I would suggest you to run this Microsoft fixit and check if it helps.
Refer:
Fix Windows system performance problems on slow Windows computers
https://support.microsoft.com/en-us/mats/slow_windows_performance
Please also run Microsoft safety scanner to check for any virus or malware which may be causing the issue.
Refer:
http://www.microsoft.com/security/scanner/en-us/default.aspx
Note: Any data files that are infected may only be cleaned by deleting the file entirely, which means there is a potential for data loss.
I hope this information helps.
Thank you
52 additional answers
    2017-12-11T18:22:03+00:00
    0xc0000022
    2017-12-28T02:12:09+00:00
    fortnite
    2017-12-28T02:31:38+00:00
    sir  system automatically click open and shut computer system mean i try to save my son photos and albums and document  to save some available microsoft photo manager not added fully in my  prasanna photo d drive not succedd  not known  we are always visit microsoft  and good help from you many times but now i am failure and not known  my son photo from 2013 to still  not including not fine so i request yesterday  only i want whatever the photo document horoscope available same protect and save d drive in computer prasanna photo d drive help
    thanks
    2018-03-17T00:04:05+00:00
    I am getting an error:  The application was unable to start correctly (0xc0000022). Click ok to close application.
    I keep getting this error over and over - even with shutting down computer and coming back in.  This has been going on for months and I am sick of it.
