System Recovery Failed Error "0xc0000022"
2010-08-13T16:47:37+00:00
original title: HAVING ERROR "0xc0000022" due to which recovery was not successful.plz help
i did the recovery procedure on my laptop but got msg..
due to erroe "0xc0000022" recovery was not successful
2015-04-02T16:54:34+00:00
Hello Resalat,
Thank you for the response.
I appreciate your time.
As you mentioned that Windows is slow, I would suggest you to run this Microsoft fixit and check if it helps.
Refer:
Fix Windows system performance problems on slow Windows computers
https://support.microsoft.com/en-us/mats/slow_windows_performance
Please also run Microsoft safety scanner to check for any virus or malware which may be causing the issue.
Refer:
http://www.microsoft.com/security/scanner/en-us/default.aspx
Note: Any data files that are infected may only be cleaned by deleting the file entirely, which means there is a potential for data loss.
I hope this information helps.
Thank you
52 additional answers
    2016-12-13T09:51:35+00:00
    Thank you for your kindness. Meanwhile I opted for Win 10 and got rid of the bug's Win 7. Thanks again!
    2017-02-06T13:28:48+00:00
    I was getting   0xc0000022.   I went to settings, then to apps and deleted "shared c run-time for x64  McAfee.   I ran 4 places I was getting the message  0xc0000022 and no longer receive the error message !!!   I hope it is fixed !!!
    2017-04-13T12:13:00+00:00
    I also have been receiving error 0xc0000022.   I re-installed Windows 10 and no longer receive the error message.
    2017-11-16T14:22:10+00:00
    Having error code 0xc0000022  not sure how to fix.
