Download and install the latest nVidia driver for your graphics card.
I click "Address a problem with NVIDIA graphics driver" and it says "This solution could not be downloaded".
I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later.
I am connected to the internet, and windows update works, web browsing works etc. Why isn't it downloading the solution?
71 additional answers
2010-05-12T19:06:29+00:00 as from above after reading through all that junk,.. its been crashing since about 5/10/2010, windows update, and driver release update. i check for updates once a week and it caught me there,.. i play on games like World of Warcraft (havent noticed it much there), Left4Dead2 (crashes within 5-10 mins freezes and noise polution, and Borderlands, (strangely enough it kills sound and looks like people are shooting 5billion bullets per shot =.=)
im not going to bother listing the dxdiag and dmb files since theres been no response to the people that have been listing them, id rather see what their fixes are before making this page any longer to read through.
ill give it til the end of tonight then ill be trying a rollback on my entire system to a date before 5/10. then ill be calling microsofts solution center for the next 268 hours =.=
i have to run basic tasks such as replying to this message in safe mode just from fear of it crashing for loading a program...
any solutions or temporary fixes at this point would be a blessing.
regards,
KBarlow
After reading a few other threads on crashing and freezing and ballistics gone mad, ive noticed the one keyword all the other people are using,...
64-bit
i originally had my computer on win-7 32-bit, never a care in the word, nothing crashed nothing froze over, no problems (later on in my hard drive crashed beyond repair, so i was given the opportunity to upgrade to win-7 64-bit, i read forums after forums telling me that its basically the same with a few changes to memory usage etc. so i took it upgraded to 64 bit. for the first month or two i didnt notice anything different, until the 2nd month where i swear it seemed as if my computer was now running games "Slower" than it was on 32 bit, which i assumed it would have been faster. i didnt think much of it and just continued through the month ignore the occasional flicker.
Now i am in month 3 and i started recieving random crashes with in games (left4dead2) where the game would freeze and random sounds flooded out of my speakers., alt tabbing doesnt get you out of it, u can rather control alt delete, open processes and disable it in processes, or once processes is open right click its tab at teh bottom and click close.
now i am getting a crash on everything i use, run a game crashes in 5 mins, run a video from the cd drive, crashes in 5 mins, load up any kind of internet surfer, explorer,chrome,firefox, mozilla, all crash in a few minutes after using them.
Spent my last 10 huors going through posts after posts after replies after paragraphs in every help trouble shoot site i can find for windows, and nvidia. Thus i am here. (typing on a labtop not having this issue since its 32 bit vista)
Thus the problem solution i am starting to come aroudn too, isnt your drivers, its not your monitor, not the motherboard, not your ram or any programs your using,.. the problem is Windows 7's 64-bit operating system,
yes ive seen all the commercials and trailers, win 7 thats my idea, its wonderful its great, its fast and easy to use, blah blah blah, you know why they dont show a commercial of a gamer using any of the new windows, cuz hed be on there cussing at it throwing keyboards against the walls and telling you to stick with windows xp!
So your solution isnt going to be a anytime near the future fix. its too virgin of an operating system, you can rather a) if you have the full win 7 disc, reformat into 32 bit, or switch to vista 32 bit, or switch in anything works xp.
Good luck to you all im reformating tonight.
Regards,
Kory "Caradi" Barlow
2010-06-09T16:05:30+00:00 I too am having the same problem BUT my problem is that the unexpected shutdown causes it. I had sleep mode set to activate after 1 hour of idle time and thats when I got the blue screens and warnings. I now use hibernate which was hard to find but i am no longer getting the warnings and blue screens. I was also getting the same info about not being able to connect and when I finally went to NVIDIAS site to upload the latest driver it said I was up to date. It seems that the power saver settings clash with NVIDIA. If anyone gets more info on this particular problem I would love to investigate it. I have limited computer knowledge and this is as far as I can get on this problem.
2010-06-13T23:39:12+00:00 I too am suffering from everyone else is describing here. This started in late May. This happened with the previous and current versions of the NVidia Driver. I too am using 64 bit Win 7 Home Premium. My problem has now escalated as Windows is now booting into a 640 x 480 mode. When I checked the Device Manger the listing for my NVidia GeForce 8800 GTS; I receive: "Device Status: Windows has stopped this device because it has reported problems. (Code 43)".
I tried removing and re-installing the NVidia drivers with no luck. I notice that the graphics card is doing something odd during the boot: the screen has turned to gibberish. The ASUS motherboard logo has disappeared. The computer is almost unusable in this situation.
When doing a search on nvlddmkm.sys there are a ton of people all offering a multitude of solutions for this problem. It is odd how different they are:
Don't overclock your system (I don't)
Use only one stick of memory (???)
Remove update KB952287 (I never had it)
Remove un-necessary power from mother board (I have no extra cards installed), etc.
One thing I have not seen here is a solution for this problem. Why if it is showing up on so many system has it not been addressed.
Please help
2010-09-26T14:59:08+00:00 I too am suffering from everyone else is describing here. This started in late May. This happened with the previous and current versions of the NVidia Driver. I too am using 64 bit Win 7 Home Premium. My problem has now escalated as Windows is now booting into a 640 x 480 mode. When I checked the Device Manger the listing for my NVidia GeForce 8800 GTS; I receive: "Device Status: Windows has stopped this device because it has reported problems. (Code 43)".
Please help
Exact same issue "This solution could not be downloaded". Drivers up to date, connected to the internet, blah, blah. DXDIAG below:
System Information
Time of this report: 9/26/2010, 09:54:08
Machine name: DAD-PC
Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-870A-UD3
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Phenom(tm) II X4 965 Processor (4 CPUs), ~3.4GHz
Memory: 8192MB RAM
Available OS Memory: 8190MB RAM
Page File: 2657MB used, 13719MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTS 250
Manufacturer: NVIDIA
Chip type: GeForce GTS 250
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0615&SUBSYS_26051682&REV_A2
Display Memory: 4069 MB
Dedicated Memory: 997 MB
Shared Memory: 3071 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Hanns.G HG281
Monitor Model: Hanns.G HG281
Monitor Id: HSD1CF3
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.5896 (English)
Driver Version: 8.17.12.5896
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 7/9/2010 17:38:00, 12471400 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4555-11CF-3A62-09061CC2C535}
Vendor ID: 0x10DE
Device ID: 0x0615
SubSys ID: 0x26051682
Revision ID: 0x00A2
Driver Strong Name: oem23.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section003:8.17.12.5896:pci\ven_10de&dev_0615
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1458A102&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6101 (English)
WHQL Logo'd: Yes
Date and Size: 4/30/2010 04:06:04, 2359200 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Realtek Digital Input (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
- USB Root Hub
| Vendor/Product ID: 0x1002, 0x4397
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/13/2009 19:07:09, 343040 bytes
| Driver: usbd.sys, 7/13/2009 19:06:23, 7936 bytes
Gameport Devices
PS/2 Devices
- Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/13/2009 18:19:57, 105472 bytes
| Driver: kbdclass.sys, 7/13/2009 20:48:04, 50768 bytes
- Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
- HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC018
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/13/2009 19:00:20, 31232 bytes
| Driver: mouclass.sys, 7/13/2009 20:48:27, 49216 bytes
- Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/13/2009 20:45:55, 62544 bytes
| Driver: sermouse.sys, 7/13/2009 19:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 605.3 GB
Total Space: 715.4 GB
File System: NTFS
Model: SAMSUNG HD753LJ ATA Device
Drive: F:
Free Space: 534.8 GB
File System: NTFS
Drive: G:
Free Space: 129.5 GB
Total Space: 953.9 GB
File System: NTFS
Model: ST31000520AS ATA Device
Drive: H:
Free Space: 325.7 GB
File System: NTFS
Model: SAMSUNG HD103SJ ATA Device
Drive: M:
Free Space: 431.7 GB
File System: NTFS
Model: Maxtor OneTouch USB Device
Drive: D:
Model: SATA HL-DT-STDVDRAM G SCSI CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 18:19:54, 147456 bytes
Drive: E:
Model: SATA Optiarc DVD RW A SCSI CdRom Device
System Devices
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1002&DEV_43A2&SUBSYS_00001002&REV_00\3&18D45AA6&0&AA
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 20:45:45, 183872 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_50041458&REV_00\3&18D45AA6&0&90
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7600.16385 (English), 7/13/2009 19:06:30, 25600 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 19:06:31, 324608 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/13/2009 19:07:09, 343040 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&18D45AA6&0&C4
Driver: n/a
Device ID: PCI\VEN_1002&DEV_43A1&SUBSYS_00001002&REV_00\3&18D45AA6&0&A9
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_50041458&REV_00\3&18D45AA6&0&B2
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 19:06:30, 51200 bytes
Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&18D45AA6&0&C3
Driver: n/a
Device ID: PCI\VEN_1002&DEV_597F&SUBSYS_59571002&REV_00\3&18D45AA6&0&50
Device ID: PCI\VEN_1002&DEV_43A0&SUBSYS_00001002&REV_00\3&18D45AA6&0&A8
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_50041458&REV_00\3&18D45AA6&0&9A
Name: GIGABYTE GBB36X Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_B0001458&REV_03\4&88E5031&0&0050
Driver: C:\Windows\system32\DRIVERS\jraid.sys, 1.17.0043.0005 (English), 11/3/2008 21:21:08, 98144 bytes
Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&18D45AA6&0&C2
Driver: n/a
Device ID: PCI\VEN_1002&DEV_597E&SUBSYS_59571002&REV_00\3&18D45AA6&0&48
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_439D1002&REV_40\3&18D45AA6&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 20:48:27, 15424 bytes
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_50041458&REV_00\3&18D45AA6&0&92
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_B0001458&REV_02\4&1A75311A&0&00A8
Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&18D45AA6&0&C1
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_439C&SUBSYS_50021458&REV_40\3&18D45AA6&0&A1
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 20:45:45, 12352 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 20:45:46, 48720 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 20:52:21, 24128 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 20:52:21, 155728 bytes
Device ID: PCI\VEN_1002&DEV_4390&SUBSYS_B0021458&REV_40\3&18D45AA6&0&88
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_03\4&3694E160&0&00A9
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&18D45AA6&0&C0
Driver: n/a
Device ID: PCI\VEN_1002&DEV_5978&SUBSYS_59571002&REV_00\3&18D45AA6&0&10
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_50041458&REV_00\3&18D45AA6&0&A5
Name: ATI I/O Communications Processor SMBus Controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_00000000&REV_41\3&18D45AA6&0&A0
Driver: n/a
Name: NVIDIA GeForce GTS 250
Device ID: PCI\VEN_10DE&DEV_0615&SUBSYS_26051682&REV_A2\4&2B98F9DC&0&0010
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 189032 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/9/2010 17:38:00, 261268 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_neutral_e3981c6eee5931b7\NvCplSetupEng.exe, 14.00.0000.0162 (English), 7/9/2010 17:38:00, 23969016 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 11240 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 13187176 bytes
Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 7/9/2010 17:38:00, 65128 bytes
Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 4/3/2010 17:55:31, 930272 bytes
Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 2037864 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 6.14.0012.5896 (English), 7/9/2010 17:38:00, 14513768 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 6116968 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.5896 (English), 7/9/2010 17:38:00, 2761832 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 3089512 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 12471400 bytes
Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 382568 bytes
Driver: C:\Windows\system32\nvinfo.pb, 7/9/2010 17:38:00, 12264 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 19114088 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 7002216 bytes
Driver: C:\Windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 7/9/2010 17:38:00, 56936 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 1625192 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 6.14.0012.5896 (English), 7/9/2010 17:38:00, 10267240 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 4553832 bytes
Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.5896 (English), 7/9/2010 17:38:00, 2506344 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 2892904 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 9818728 bytes
Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 314984 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 14092904 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.5896 (English), 7/9/2010 17:38:00, 5107816 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 7/9/2010 17:38:00, 24011 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0062.0040 (English), 7/9/2010 17:38:00, 660072 bytes
Driver: C:\Windows\system32\nvcod.dll, 1.09.0022.0107 (English), 7/9/2010 17:38:00, 260712 bytes
Driver: C:\Windows\system32\nvcod1922.dll, 1.09.0022.0107 (English), 7/9/2010 17:38:00, 260712 bytes
Device ID: PCI\VEN_1002&DEV_5957&SUBSYS_59571002&REV_00\3&18D45AA6&0&00
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_50041458&REV_00\3&18D45AA6&0&B0
Name: ATI I/O Communications Processor PCI Bus Controller
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40\3&18D45AA6&0&A4
Name: Texas Instruments 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_10001458&REV_00\4&340CE6FE&0&70A4
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 19:07:13, 227840 bytes
Device ID: PCI\VEN_1002&DEV_43A3&SUBSYS_00001002&REV_00\3&18D45AA6&0&AB
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_50041458&REV_00\3&18D45AA6&0&98
Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_A1021458&REV_40\3&18D45AA6&0&A2
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 19:06:13, 122368 bytes
Name: NEC Electronics USB 3.0 Host Controller
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_50071458&REV_03\4&91A636&0&0048
Driver: C:\Windows\system32\DRIVERS\nusb3xhc.sys, 1.00.0018.0000 (English), 11/20/2009 06:16:02, 177152 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16590
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.01.0001.0014
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
File writer,0x0020000
