5.1 Surround Sound speaker system not working in Windows 7 Professional 64bit edition
2010-03-21T05:06:14+00:00
My problem is pretty much the same as other users who can't get their surround sound speaker system to function properly in Windows 7.
I have a subwoofer and 5 speakers (2 for front, 2 for rear, 1 for center).  Connection to the on-board RealTek HD Audio is simple, orange for the subwoofer, green for front and black for rear.
Testing the sound in the RealTek HD Audio Manager and Control Panel->Sound windows produces a sound on all channels at the same time, which is the desired setup.
However different applications use different channels.  IE and Firefox uses the front channels, VLC/MediaPlayer uses the rear.  3D games (ie WoW) uses all channels.  In each case the subwoofer doesn't work.
I have already tried downloading the latest drivers from the motherboard manufacturers website (Gigabyte).  I even tried the RealTek provided drivers (even though on RealTek's website that is NOT recommended).  I have tried connecting the subwoofer connectors to different jacks (reversed black and green).
I have experimented with the settings in the RealTek HD Audio Manager and Control Panel->Sound windows.  Nothing works.
These exact same subwoofer and speakers worked perfectly fine in Windows XP.
I have 2 questions:
a) Has anyone resolved their 5.1 & Windows 7 problem doing something I haven't tried yet?
b) When is Microsoft going to take this problem seriously?  All of the Microsoft provided answers just repeats what everyone else
has already tried.
2013-04-13T14:42:48+00:00
First unplug 3 cable (orange, green and black)  then Go to control panel - Hardware and sound - Real tek HD audio manager - tick center, subwoofer and rear pair,  front left and right  and speaker fill
Then click  Device advance settings.
select  "make front and rear output devices playback two different audio streams simultaneously" and give ok
The plug all the three pin one by one and  select proper option in the popup windows.
thats all.
You didn't give me enough information to get this working.   My system runs Win 7 X64 Home Premium.   When I select 5.1 sound as the capability the side speakers of my Logitech x550's are not recognized.  If I select 7.1, which is the chipset capacity of my Realtek chip, I can get the two outside speakers enabled as "rear" speakers. and can push test tones to each of the four surrounding speakers and to the center/bass combination via the Realtek driver.
As far as the "make front and rear output devices playback two different audio streams simultaneously" is concerned... I can't find this option.  There are at least two providers of "control interfaces" active on my system.  One is provided by RealTek, the other by Microsoft.  The paths to these interfaces is circuitous and confusing, to say the least.
IMHO some compromises are in order.  I've got my Pandora One stream playing acceptably in my small study.  Many of the source sounds streamed for me are recorded in stereo, or even mono, so I find myself hitting the "matrix" button on my Logitech X550 control fairly frequently.  Occasionally a newer piece is delivered which actually sounds Ok without the "matrix" decoder.
What I would really like to be able to do is to "reconfigure on the fly" between the built in USB speaker bar on my Acer Z3731 "All in One" system and my external Logitech X550's with the capacity for 5.1 "surround sound" presentation via three wires.  When I try your procedure, I don't get separate recognition of each wire as it is plugged in and often end up with 2.1 sound being pushed out to my 5.1 external speakers because somehow Microsoft has re-recognized the built in USB based sound bar instead of the three rear wires plugged into the jacks provided by the system manufacturer.
If there ever were separate "Speakers" and "Realtek" icons displayed in the user interfaces on my system, the speakers are long gone and I can't get them back.  All I see is the Realtek driver.  I would like to see two different "Speakers" Icons I could label "Built-in 2.1" and "External 5.1" in addition to the Realtek driver.  How do I get these to reappear?
Can anyone suggest a way to have two different sets of "speakers" recognized and identified within the Microsoft UI in addition to the Realtec driver?  If I could get this done, I believe the driver would let me "set as default" one or the other speaker set, and I'd have "software switching" capable of letting me choose whether the external speakers or the built in sound bar delivers the sound.
49 additional answers
    2013-05-02T18:05:21+00:00
    Hey friend i finally found the solution of this problem, go to sound card setting and disable speakers via properties and remove all the speakers plugged in pc, then open realtek it says device is disabled and then plugin 3.5 mm jack of speakers in the jack other then green one, realtek driver will ask u questions like rear speaker and many more choose rear speakers and now plugin other 3.5 mm jack of speaker and voila done u will get independent sound from each rear and front speaker.
    2013-07-08T15:43:59+00:00
    Could some one can explain me why this "things" works on firefox but not on chrome/mplayer ??
    2013-07-15T08:29:25+00:00
    Considering the age of the thread and to avoid confusion, if the troubleshooting steps in this thread did not resolve your issue I would recommend creating a new thread so that the community can focus on that thread. Refer to the following link prior to posting a question so that you may provide all the relevant information, for us to help you:
    http://support.microsoft.com/kb/555375
    2015-02-01T03:50:06+00:00
    worked for me thanks
    ******@hotmail.com
