Hard Drive activity light constantly blinking - new WIN7 Ultimate Dell PC
2009-12-05T23:05:42+00:00
I've been troubleshooting this problem off and on for weeks on my brand new WIN-7 64 Ultimate Dell XPS 8000 (I7-860 1TB HD 8GB Ram).    Searching around has found many recommendations and a couple of resolved issues, (more non-resolved), but none of the recommendations has helped me.
I got a feeling that this may be a Dell-specific issue, but I got no response in the Dell forums.   I'm sure if I call Dell support, all I will get is recommendation to put it back to factory default.  no thanks!
I have disabled all the suspects, at least temporarily to see if it has an affect:
Windows Indexing & Search
Windows Firewall
Windows Defender
System Restore
Remote Differential Compression
Windows Fax & Scan
Superfetch
Seaport
With all these off, the blinking was clearly less busy, but there was still a steady heartbeat type of blink.   I since re-enabled Defender and System Restore.    (Even if they were to blame, that is hardly an acceptable solution/workaround!!!)
I've studied disk activity in PERFMON and there is some occasional kernel activity and event logging.  I took a couple of window snapshots I can post (if I can figure how).   I also created HijackThis log.
Sometimes the disk activity PERFMON window is blank but yet the light continues to blink!!!  huh???
I have not disabled hibernate (there was a suggestion somewhere it could be involved).  I use it regularly.   But I can try that too you think it might help.
I am at my wits end and a little overwhelmed at all the data to study and search for.  I hate diddling with services and the registry, fearful of getting in over my head and creating a mess I can't get out of.
Also, there is no additional security software and I did not install any preinstalled trial crapola.
Help!!!!!!!!
I will post the hijack this log in the next post
  Update to clarify:  What I reported above is basically about out-of-the-box behavior... not application or CPU-bound related. The system was pretty clean with minimal extra software/hardware installed.
2012-09-23T00:01:56+00:00
Hard drive light blinks quckly because Microsoft does what is called something like  Write Cache Flushing ... flushes disk drive writes that might be in that cache to disk?  Simple.
The reason is .. if you have a power failure.. you will lose some data from that cache and/or corrupt something that may be important.   Takes a hit on drive performance and life expectancy too.  So some of the experts say.
If you have a battery backup.. or most laptops with a battery can.. Disable it!
.. In device manager the hard drive properties usually has a check box for enable write caching ..  and some will have another check box...  Disable Microsoft Write Cache Flushing.    <  add a check to that guys box...now look at your non very often blinking Hdd light... works  same with some of the DVD/CD drives, same controllers probably. .
46 additional answers
    2010-01-18T17:59:09+00:00
    Mine blinks every second too ! New Gateway DX4820 , Seagate, 750 GB , blinked since I took it out of the box ... any suggestions ?
    2010-01-18T19:26:25+00:00
    Well mine turned out to be the backup built into windows. Didn't realize it was on and set to do automatic backups. so the wbengine.exe belongs to Windows back up. Check to see if your backup is turned on.
    2010-01-18T19:42:14+00:00
    No luck... still one blink every second   : (
    2010-01-19T15:25:12+00:00
    fwiw, I gave up on this.  erlyrisa's response makes sense.   Plus I need a lot of those services... indexing seems critical with WIN7.
    I am just going to be prepared to lose a hard drive in the future and be really good about backups (external hard drive) in the meantime.    I did shut off Windows Backups (pros and cons, may reconsider)  and am trying out a 3rd party product.   Windows Backups seemed a large part of it.
    Maybe newer hard drive's will handle the newer stay-busy algorithms.  Maybe, just maybe, the algorithms actually know what they are doing and hardware and software are in harmony.   nah...  new harddrive in x years.    I also have a smaller external hard drive... maybe I will come up with a rotating scheme to do double-backups.
