Hard Drive activity light constantly blinking - new WIN7 Ultimate Dell PC
2009-12-05T23:05:42+00:00
I've been troubleshooting this problem off and on for weeks on my brand new WIN-7 64 Ultimate Dell XPS 8000 (I7-860 1TB HD 8GB Ram).    Searching around has found many recommendations and a couple of resolved issues, (more non-resolved), but none of the recommendations has helped me.
I got a feeling that this may be a Dell-specific issue, but I got no response in the Dell forums.   I'm sure if I call Dell support, all I will get is recommendation to put it back to factory default.  no thanks!
I have disabled all the suspects, at least temporarily to see if it has an affect:
Windows Indexing & Search
Windows Firewall
Windows Defender
System Restore
Remote Differential Compression
Windows Fax & Scan
Superfetch
Seaport
With all these off, the blinking was clearly less busy, but there was still a steady heartbeat type of blink.   I since re-enabled Defender and System Restore.    (Even if they were to blame, that is hardly an acceptable solution/workaround!!!)
I've studied disk activity in PERFMON and there is some occasional kernel activity and event logging.  I took a couple of window snapshots I can post (if I can figure how).   I also created HijackThis log.
Sometimes the disk activity PERFMON window is blank but yet the light continues to blink!!!  huh???
I have not disabled hibernate (there was a suggestion somewhere it could be involved).  I use it regularly.   But I can try that too you think it might help.
I am at my wits end and a little overwhelmed at all the data to study and search for.  I hate diddling with services and the registry, fearful of getting in over my head and creating a mess I can't get out of.
Also, there is no additional security software and I did not install any preinstalled trial crapola.
Help!!!!!!!!
I will post the hijack this log in the next post
  Update to clarify:  What I reported above is basically about out-of-the-box behavior... not application or CPU-bound related. The system was pretty clean with minimal extra software/hardware installed.
2012-09-23T00:01:56+00:00
Hard drive light blinks quckly because Microsoft does what is called something like  Write Cache Flushing ... flushes disk drive writes that might be in that cache to disk?  Simple.
The reason is .. if you have a power failure.. you will lose some data from that cache and/or corrupt something that may be important.   Takes a hit on drive performance and life expectancy too.  So some of the experts say.
If you have a battery backup.. or most laptops with a battery can.. Disable it!
.. In device manager the hard drive properties usually has a check box for enable write caching ..  and some will have another check box...  Disable Microsoft Write Cache Flushing.    <  add a check to that guys box...now look at your non very often blinking Hdd light... works  same with some of the DVD/CD drives, same controllers probably. .
46 additional answers
    2009-12-05T23:27:53+00:00
    Notice a lot of "file missing" on some services at the bottom of the log.   That doesnt look good.  maybe a HijackThis issue because note that it logged the log as an "Unknown Windows".
    2009-12-05T23:25:43+00:00
    Logfile of Trend Micro HijackThis v2.0.2
    Scan saved at 9:10:42 AM, on 12/3/2009
    Platform: Unknown Windows (WinNT 6.01.3504)
    MSIE: Internet Explorer v8.00 (8.00.7600.16385)
    Boot mode: Normal
    Running processes:
    C:\Program Files (x86)\Java\jre6\bin\jusched.exe
    C:\Program Files (x86)\Multimedia Card Reader(9106)\ShwiconXP9106.exe
    C:\Program Files (x86)\CyberLink\PowerDVD DX\PDVDDXSrv.exe
    C:\Program Files (x86)\iTunes\iTunesHelper.exe
    C:\Program Files\Logitech\SetPoint\x86\SetPoint32.exe
    C:\Program Files\HijackThis\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://g.msn.com/USCON/1
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
    R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
    F2 - REG:system.ini: UserInit=userinit.exe
    O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
    O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files (x86)\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
    O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll
    O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
    O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
    O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files (x86)\Windows Live\Toolbar\wltcore.dll
    O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files (x86)\Windows Live\Toolbar\wltcore.dll
    O4 - HKLM..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Java\jre6\bin\jusched.exe"
    O4 - HKLM..\Run: [ShwiconXP9106] C:\Program Files (x86)\Multimedia Card Reader(9106)\ShwiconXP9106.exe
    O4 - HKLM..\Run: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
    O4 - HKLM..\Run: [PDVDDXSrv] "C:\Program Files (x86)\CyberLink\PowerDVD DX\PDVDDXSrv.exe"
    O4 - HKLM..\Run: [GrooveMonitor] "C:\Program Files (x86)\Microsoft Office\Office12\GrooveMonitor.exe"
    O4 - HKLM..\Run: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
    O4 - HKUS\S-1-5-19..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-19..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-20..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
    O4 - HKUS\S-1-5-20..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
    O4 - .DEFAULT User Startup: Dell Dock First Run.lnk = C:\Program Files\Dell\DellDock\DellDock.exe (User 'Default user')
    O4 - Global Startup: Device Detector 3.lnk = C:\Program Files (x86)\Olympus\DeviceDetector\DevDtct2.exe
    O4 - Global Startup: Logitech SetPoint.lnk = ?
    O8 - Extra context menu item: Add to Google Photos Screensa&ver - res://C:\Windows\system32\GPhotos.scr/200
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~2\Office12\EXCEL.EXE/3000
    O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
    O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
    O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
    O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MIFE82~1\Office12\REFIEBAR.DLL
    O13 - Gopher Prefix:
    O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveSystemServices.dll
    O23 - Service: Andrea RT Filters Service (AERTFilters) - Andrea Electronics Corporation - C:\Program Files\Realtek\Audio\HDA\AERTSr64.exe
    O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
    O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
    O23 - Service: Dock Login Service (DockLoginService) - Stardock Corporation - C:\Program Files\Dell\DellDock\DockLogin.exe
    O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
    O23 - Service: Seagate Service (FreeAgentGoNext Service) - Seagate Technology LLC - C:\Program Files (x86)\Seagate\SeagateManager\Sync\FreeAgentService.exe
    O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: Logitech Bluetooth Service (LBTServ) - Logitech, Inc. - C:\Program Files\Common Files\Logishrd\Bluetooth\LBTServ.exe
    O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
    O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
    O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: RoxMediaDB10 - Sonic Solutions - c:\Program Files (x86)\Common Files\Roxio Shared\10.0\SharedCOM\RoxMediaDB10.exe
    O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
    O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
    O23 - Service: stllssvr - MicroVision Development, Inc. - c:\Program Files (x86)\Common Files\SureThing Shared\stllssvr.exe
    O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
    O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
    O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
    O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
    O23 - Service: Dell Wireless WLAN Tray Service (wltrysvc) - Unknown owner - C:\Program Files\Dell\Dell Wireless WLAN Card\WLTRYSVC.EXE
    O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
    End of file - 8830 bytes
