Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2011-04-06T14:54:12+00:00
    This does not work for me.  Each time I delete the file in the interfaces folder, it comes back upon reboot.  This is driving me crazy.
    2011-04-11T19:21:00+00:00
    After i went into Services and set full administrator rights in the Security tab, I used method 2 and voila! Perfect, thank you so much.
    2011-06-21T10:07:46+00:00
    Navigate to
    Win7 Pro at home (not on a domain). 3 WLANs available, 1 prime, 2 back up spares. Stopped "wlan auto config" service. Only folder with contents was "interfaces" this was more folders with names enclosed in {curly braces}. Deleted. Got back the "Connect Automatically" option for primary network. Signed on OK. Rebooted, but system failed to auto connect. Got the network tray icon with the yellow star. Signed on manually as usual. Auto connect option gone again. Auto Connect option IS available and checked in backup networks. UNchecking them is a placebo. Next time I check, they are checked again. In Manage Networks I cannot see (I am logged on as an administrator) the two alternate networks. If I could, I'd delete them. So procedure failed, problem sill exists - no auto connect. 8-{
