Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2010-02-16T16:44:32+00:00
    Have again gone thru all steps recommended.  When I enable the Hidden Built-in Administrator Account, the user profile service logs me in w/default profile.  Pop-up states that "C:\Windows\sys32\config\systemprofile" that desktop refers to a location that is unavailable.
    I have an HP dv8t that came w/pre-installed Windows 7 Professional.  Is it possible that my pre-installed OS does not contain Administrative account/privilege?  If not, can I obtain it?  When I right click on any folder- then properties-security, it lists the following group or user names - Creator Owner - System - Administrators (MyName-PC\Administrators) and Users )MyName-PC\Users.
    As Administrator and User, I have Full Control except for Special Permissions. Is that what is preventing me from adding my active network in Manage wireless networks?  My active network has never shown there.
    When I first got PC, wireless did not work at all.  HP tech connected remotely and spent over an hour trying to get it to work.  Had to restore to factory installed condition which corrected that problem.
    Just hope this additional info helps.
    2010-03-10T15:32:38+00:00
    I also have the same problem as Smokey55. The catch is, Umesh P, there are no visible active networks on the network and sharing center, AND if you try to add one the nasty access is denied message appears.
     I have a feeling the connections are there, but hidden. Also, on a normal Windows 7 installation, when you click on the wireless connection from the taskbar, 3 options should be there: connect/disconnect, status and properties. Now, the properties option has just vanished. Inside that option should be the "Autoconnect at loggon" box.
    If it helps, I will tell you this problem showed up after I installed the intel ProSet for windows and Advanced Network services. Uninstalling it had no affect. Still, I can detect  and connect to my access point, but I do have to type the password each time. I even checked all the windows services through services.msc looking for some crucial service disabled or enabled, to no solution. Finally, the windows firewall is turned off. This really smells like a security problem, but I am getting short of ideas, some help, plz :-)
    Tried all the stuff Smokey did, but got the same results.
    2010-03-10T21:59:07+00:00
    Hi Umesh. Similar to the original poster, my Windows 7 laptop refuses to automatically connect--but the problem is with one particular wireless network. I notice that the problematic wireless network does *not* have a "Connect automatically" checkbox. This wireless network uses WEP encryption. Is Windows 7 unable to be configured to automatically connect to wireless networks having WEP encryption?
