Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2016-07-15T05:46:21+00:00
    Took me a full day of seeking & trying all other recommendations without success.
    But it was this that worked in the end:
    Method 1: Make sure if the WLAN AutoConfig service is set to automatic.
    1. Click on start button, type services.msc and press Enter.
    2. Scroll down to the WLAN AutoConfig service, right click on it and select Properties
    3. Click on General tab, select Automatic for startup type.
    4. Click on Dependences tab and make sure that all the dependences services are set to Automatic. Then click on OK button.
    2016-07-25T16:03:10+00:00
    You have no idea how long I've been unable to allow my computer to "connect automatically" on boot. Previous to this effort, I've Googled and tried various solutions around every two or three months. To help others, I'm going to detail my problem exactly.
    SYMPTOM
    If I allow to connect automatically by checking the box, then reboot computer, my connection is connected but with RED X. I have to disconnect and then reconnect. Sometimes I have to do this more than once.
    MY WORK-AROUND (until the above solution)
    I just didn't let the computer connect automatically and after boot I just connect to wifi manually. I'm so used to doing it now it's second nature.
    Thank you very much.
    CR
    2016-07-25T19:51:34+00:00
    Hi C Rowe
    It's good to know that after 6 years my solution is still helping people, just a shame that Microsoft haven't got round to offering a solution that works.
    Don241
