Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2013-05-01T10:46:57+00:00
    I went through all the hoops on this one and finally found the answer in case it helps anyone else.
    It all started after I got a new router.
    I deleted profiles and found they just appeared again after. Nothing worked.
    Finally it dawned on me. Windows was not managing my wireless networks!  I had third party software from EdiMax for my wireless card.   All I had to do was go into that software and delete the old network and re-config the new one.
    So, check you haven't got third party wireless software before you do anything else.
    Hope this helps
    Gus
    2013-09-14T16:55:31+00:00
    you say to use Windows Explorer to find:  \programdata/wlansvc......
    I'm on WIN7, when I open Windows Explorer, and search "computer" or "library", etc, cannot locate the "programdata" file?
    +++++++++Nevermind, found it by entering "c:\programdata"  in the search box and then selecting "microsoft, etc...++++++++++
    2013-09-14T18:08:30+00:00
    I muddled my way through your instructions and when I restarted the computer, it would not auto connect. i opened "manage my wireless networks" and the connection was specified "automatically connect", but it wasn't connecting.  It would connect manually.  Then I undid your last instruction by unchecking the READ-ONLY boxes.  Restarted, and it connected automatically.  Did a couple more restarts and it still connects automatically.  Go figure...
    THANK  YOU FOR YOUR ASSISTANCE !
