Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2011-12-02T03:37:00+00:00
    SOLUTION! (at least for me on my win7 laptop)
    I just had this problem when I reinstalled the OS from the OEM disc (not the factory install disc) I figured the OEM disc had a driver conflict. And I even tried updating the latest Wireless driver. But I incorrectly pointed the finger at the wireless lan driver.
    The HOT KEY strip (the one with the buttons that turn white when you touch them just above the keyboard) on my laptop also controls the Wi-Fi Radio on/off button. This was the problem. You need the original driver for that strip, even if your volume on the strip is working.
    Background. Think of your wireless lan as two seperate devices… the radio is compared to the cord of an ethernet connection. The wireless lan card is the ethernet card. When you think about it as one device it is easy to see why so many people assume the problem is with the wireless lan card. But the important part is that a laptop usually divides the two up to save power. Controlling the radio from a button on the keyboard (or a function key) (mine is FN +F2) is another reason to think of the two as seperate items.
    Before reaching this conclusion I tried using “allow the computer to turn this device off to save power” I also had tried High performance power option modes and other wireless radio from the control pannel in both plug-in and battery modes. I tried the turn wireless netork on and off as well. There were plenty of reasons to think this was going to fix the problem.
    I alos tried going with the above script but found that “WisWBSet.exe” was missing from windows 7. I also tried a Java script but could not find the key code for the FN button, nor the combination of the FN button (hold) and the F2 key combo.
    So update your HOTkey strip driver… see if that doesnt fix your problem.
    2011-12-05T03:24:30+00:00
    many times the card's software steps on the windows controller - delete the card's software controller, set up windows and you're golden
    2011-12-19T20:14:11+00:00
    Method 2 worked perfectly for me. Thanks so much. This issue with having to enter my network password has been frustrating for way too long!
