Thumbnail preview in explorer not showing thumbnails, instead default program icon
2010-09-03T20:10:54+00:00
I have tried and checked all things commonly being refered in forum,
windows explorer is not displaying thumbnails ( as it was earlier) instead it is showing default program icon ( windows photo viewer, set as default for all pictures) for all picture files like jpgs, bmps.
when I browse folder containing pictures. at first it displays thumbnails ( as it should ) and then immediately all thumbnails change to default icon.
when I double click any icon, it opens in its associated program correctly
I have checked all the common places like organize folder -> view -> 'always show icons never thumbnails' is unchecked
I have chekced group policy settings
I believe it is some little change in registery, perhaps after running a portable program RIOT -Radical Image Optimization Tool. that is a doubt anyway.
please help
2010-09-04T15:27:10+00:00
Hi Sunny,
Windows keeps a copy of all of your picture, video, and document thumbnails so they can be displayed quickly when you open a folder. The thumbnail preview problems can be resolved by clearing the thumbnail database and let the system rebuild it as and when required. To do so, use these steps:
Steps to Clear the Thumbnail Cache using Disk Cleanup
a.    Click Start, type “cleanmgr” (or typedisk cleanup) without quotes and press {ENTER}
b.    Select the system drive letter from the drop-down.
c.    Uncheck all the entries, except Thumbnails
d.    Click OK, and click Delete Files to confirm.
Alternatively, you can build thumbnail cache by going to the location below
%LocalAppData%\Microsoft\Windows\Explorer
The thumbnail database is stored globally in Windows 7 & Windows Vista, unlike Windows XP, where the thumbnail database is stored on a per-folder basis. In Windows 7 & Windows Vista, the default thumbnail cache location is as mentioned above.
Hope this information is helpful and let me know if you need any further assistance.
Mouneshwar R – Microsoft Support
Visit ourMicrosoft Answers Feedback Forum and let us know what you think
[If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.]
2012-01-10T09:48:20+00:00
I found the solution in my case accidentally.  My kids started to play Minecraft on this laptop and I realized immediately that they would do well to have more RAM.  Lo and behold, after upgrading from the stock 2 GB to the max 8 GB, all the thumbnails suddenly appeared successfully and there has been no further problem!  Yay.  It seems to me Windows 7 uses a lot of RAM to the point that 2 GB is not enough for it to perform as advertised.  HTH someone.
40 additional answers
    2013-06-24T16:49:53+00:00
    Hi....
    I had followed the following steps n i was able to view the thumbnails
    Wid Regards
    Asish Kumar
    2013-06-24T21:30:37+00:00
    This solution won't work...
    The Win8 notebook already has 8GB memory.
     My other notebook is a Dell D620, and I expanded my memory to 32 GB memory. So no problem with the memory. Also added the optional 2nd battery where the DVD/CD is stored....and that is carried in  the Notebook bag.
    2013-08-21T15:52:33+00:00
    That was the most helpful. Got my thumbnails back. Thanks.
