Low Battery Notification does not pop up when battery reaches critical level after upgrading to windows 7
2009-11-29T22:08:17+00:00
I upgraded to windows 7 recently and the battery notification does not work when the battery reaches it's critical level.  It worked fine with vista.  Before when the battery reached 25% the icon in the notification area there was a visual reminder and when the level reached 5% a pop up would occur.  Now with windows 7 I get nothing to remind me.  I checked in the power options where I can edit my power plans and the battery notification read that it was turned on.
2010-07-24T08:13:18+00:00
I was also having this problem of Windows 7 of just going into hibernate on low battery without notification.
I checked out the Microsoft site for Battery faq and how t change low battery notification which didn't tell me something I didn't already know. So I decided to experiment some. I discovered that when I changed my Critical Battery Action to "Shut Down" from "Hibernate", the Low Battery Notification popped up and  could switch to a power source. I changed the Critical Battery Action back to "Hibernate" and the Low Battery Notification still pops up. I guess the system just needed a little push :)
My install is barely a week old so I guess the installation didn't make the correct settings. Having applied some changes to the settings has caused the system to behave correctly in this case.
I hope this will help others with this issue.
Cheers
2009-11-30T19:50:34+00:00
Hi ejslate82,
Welcome to Microsoft Answers.
****I would suggest you to follow the below mentioned steps and check if this helps -
The icon might be hidden. Here's how to show the battery icon:
  1. Right-click an empty area on the taskbar, and then click Properties.
  2. Under Notification area, click Customize.
  3. In Notification Area Icons, click Turn system icons on or off.
  4. On the Turn system icons on or off page, under Behaviors, click On in the drop-down list next to Power, and then click OK.
Refer to the below mentioned links for additional guidance on the issue –
Battery meter FAQ –
http://windows.microsoft.com/en-US/windows7/Battery-meter-frequently-asked-questions
How do I change low battery notification -
http://windows.microsoft.com/en-US/windows7/How-do-I-change-the-low-battery-notification
Hope this helps. Let us know the results.
Meghmala – Microsoft Support
66 additional answers
    2013-08-16T13:06:43+00:00
    Hi ejslate82,
    Battery meter FAQ –
    2013-08-16T13:10:01+00:00
    Hi ejslate82,
    Battery meter FAQ –
    Hello .. no, I'm afraid this was not helpful to me at all ..my previous version (XP) alerted me in plenty of time with warning (audible) alarms, and I want the same from WIN7, but your answer doesn;t help me to do this ( and I work in I.T al the time ! ). Why do MS have to always keep making changes for the WORSE .. changes should only be made in Operarting system versions for the BETTER !
    2013-08-27T10:43:55+00:00
    Hi all,
    At last, my problem is solved. I faced the same problem when my laptop started hibernating suddenly without popping up any alert/notification to plug it in for charging when my battery runs low, though I had the notification option turned "On".
    All I did to solve this was just this...
    I turned "OFF" the notification option, (yes turned it "OFF")
    "Apply"ed changes
    ya! you guessed it right, again turned it "ON"
    "Apply"ed changes
    Clicked "OK".
    That's it.
    Now I am once again getting notification when my battery level goes down to 10%.
    (For those who do not know where the "notification option" we are speaking about is located,
    Windows 7
    Start->Control Panel->System and Security->Power Options->Change Plan Settings->Change Advanced Power Settings->Battery
    Windows 8
    Control Panel->All Control Panel Items->Power Options->Edit Plan Settings->Change Advanced Power settings->Battery->Low Battery Notification->On Battery->ON/OFF)
    Hope this helps.
