Low Battery Notification does not pop up when battery reaches critical level after upgrading to windows 7
2009-11-29T22:08:17+00:00
I upgraded to windows 7 recently and the battery notification does not work when the battery reaches it's critical level.  It worked fine with vista.  Before when the battery reached 25% the icon in the notification area there was a visual reminder and when the level reached 5% a pop up would occur.  Now with windows 7 I get nothing to remind me.  I checked in the power options where I can edit my power plans and the battery notification read that it was turned on.
2010-07-24T08:13:18+00:00
I was also having this problem of Windows 7 of just going into hibernate on low battery without notification.
I checked out the Microsoft site for Battery faq and how t change low battery notification which didn't tell me something I didn't already know. So I decided to experiment some. I discovered that when I changed my Critical Battery Action to "Shut Down" from "Hibernate", the Low Battery Notification popped up and  could switch to a power source. I changed the Critical Battery Action back to "Hibernate" and the Low Battery Notification still pops up. I guess the system just needed a little push :)
My install is barely a week old so I guess the installation didn't make the correct settings. Having applied some changes to the settings has caused the system to behave correctly in this case.
I hope this will help others with this issue.
Cheers
2009-11-30T19:50:34+00:00
Hi ejslate82,
Welcome to Microsoft Answers.
****I would suggest you to follow the below mentioned steps and check if this helps -
The icon might be hidden. Here's how to show the battery icon:
  1. Right-click an empty area on the taskbar, and then click Properties.
  2. Under Notification area, click Customize.
  3. In Notification Area Icons, click Turn system icons on or off.
  4. On the Turn system icons on or off page, under Behaviors, click On in the drop-down list next to Power, and then click OK.
Refer to the below mentioned links for additional guidance on the issue –
Battery meter FAQ –
http://windows.microsoft.com/en-US/windows7/Battery-meter-frequently-asked-questions
How do I change low battery notification -
http://windows.microsoft.com/en-US/windows7/How-do-I-change-the-low-battery-notification
Hope this helps. Let us know the results.
Meghmala – Microsoft Support
66 additional answers
    2010-01-29T21:29:01+00:00
    I have the exact same issue (bug) and its really gotten irritating, countless times I've been in the middle of reading or working and have had it shut down on me without any warning. The funky part is that it will show the notification when it feels like it, but at least 8-9/10 times it will not.
    Why can an open source OS like Linux get this "feature" correct yet a muli-million dollar corporation cannot?
    As per your you "recommendations" they appear irrelevant to the issue as this has to do with the POP-UP warning not the taskbar icon. And as with the previous poster the notification is set to on.
    2010-02-08T11:39:28+00:00
    I have the same problem notification of low battery is set to on yet does not notify or warn. it is a bug My problem is with a new HP probook 4510s  came with Vista Business but has been upgraded to Windows 7 . not sure if it affected Vista
    2010-04-18T22:54:20+00:00
    I have the same problem. After upgrade to windows 7 no battery meter icon. I tried going to properties-notification-customize-behaviours. On the drop down list power does not even appear. Other icons do and work properly. I tried showing hidden icons and that didn't work either. I am the administrator and only user although it hasn't asked me for a password.
