"USB Device Not recognized" error keeps popping up and USB devices do not work
2009-04-19T23:29:47+00:00
I keep recieving the USB not recognized error on my HP Vista home laptop.
2015-03-30T22:55:22+00:00
For anyone else that may be having this problem at the date I am making this comment and are running windows 8.1 there is an update that fixes it!
http://support.microsoft.com/en-us/kb/3013769#fixed\_issues
2009-05-08T16:47:16+00:00
KenRD,
I am sorry we were not able to resolve your issue for you at this time.  However, if your operating system needs to be re-installed and you do not have a copy of Windows, you will need to contact the manufacturer of your computer for assistance.  Normally OEM's place the Windows OS in a recovery partition with instructions on how to mke a CD or DVD from those files.
Thank you,
Gloria
2009-10-26T01:29:36+00:00
There is possibly an unbelievably simple solution to the “USB device not recognized ” error which worked for me. I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
!\[\](http://www.online-tech-tips.com/wp-content/uploads/2008/07/usbdevicenotrecognized-thumb.png)
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device ”.
!\[\](http://www.online-tech-tips.com/wp-content/uploads/2008/07/unknownusbdevice-thumb.png)
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY . Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that highly irritating “USB device not recognized” Windows error!
267 additional answers
  1. Reza-Ameri 45,891 Reputation points Volunteer Moderator
    2018-10-20T19:07:19+00:00
    This is old question and is already marked as answer, so I will lock this question.
    If you have any question, you may post a new one.
    Also note that support for Windows Vista already ended and you will need to use supported version of Windows:
    https://support.microsoft.com/en-us/help/22882/windows-vista-end-of-support
