Me too. I have toshiba vista laptop, and struggled until I decided to roll back to original manufacturer recovery disk, reloading everything from scratch. still didnt help. Using WEP encryption works, so I know the wireless interface on the laptop works.
but that is not acceptable as WEP is such a weak encryption - basically no security. am trying to use WPA or WPA2 encryption, which is not working for vista. laptop is a few feet from the router, so plenty of signal strength. another non-Vista laptop is running
fine. uninstalled the trial version of mcAfee. updated the vista software and all drivers. assigned an ip address to the laptop, and when it boots, I see that it is assigned that address. disabled all the ipv6. disabled the DHCP broadcast stuff. disabled the
vista firewall. ipconfig /all is shown below, which looks ok to me. never had Norton or symantic installed. tried resetting the ip stack. wired ethernet to the router works. just getting the local access only on wireless with WPA encryption. Router is fairly
new netgear WNR2000, and also tried a brand new netgear multiband router with identical results.
Could sure use some help here.
Windows IP Configuration
Host Name . . . . . . . . . . . . : BeckerFamily
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5005G Wireless Network Adapter
Physical Address. . . . . . . . . : 00-16-E3-F2-DE-BB
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.99(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet NIC
Physical Address. . . . . . . . . : 00-1B-24-20-AB-E7
DHCP Enabled. . . . . . . . . . . : Yes
