fix problem "local only" when connection is across a wireless connection
2008-12-29T21:58:54+00:00
access point appear: unidentified network
internet appear bloqued
access: Local only
connection: wireless connection.
Please help check what is the reason "local only".
ip is assigned automatically by DHCP, but is not possible to connect to internet, the problem appear only on windows vista Pcs, in my other computer with XP version the connection is good.
I have Microsoft Windows Vista Home Premium SP1.
69 additional answers
    2010-04-09T04:07:52+00:00
    Worked like a charm.  Thanks GETHOSTILE!
    2010-04-10T17:24:09+00:00
    I have the same problem with WINDOWS 7.... PLSSSSS HELP :(
    2010-04-11T01:43:43+00:00
    Do you have Norton Antivirus or have you ever had Norton Antivirus on your computer?
    Did you get it deleted completely with the Norton Removal Tool?
    Serving the Community one Computer at a time www.therushvillecomputerguy.com Please post a response to let us know whether our answer helped or not.
    2010-06-29T21:31:44+00:00
    I found the solution to my issue (which seemed the same as the original post).  I was getting the unidentified network with local only access from both wireless and wired connections on my Vista laptop while all of my other computers could connect (one XP, one Linux and one Windows 7).  Here was the solution (found at http://geekswithblogs.net/mattcampbell/archive/2007/09/30/Resetting-your-whole-IP-stack-in-Vista.aspx):
    Run cmd.exe as administrator and do the following:
    ipconfig /f
    nbtstat -R
    nbtstat -RR
    netsh int reset all
    netsh int ip reset
    net winsock reset
    I received an error on one or two of these, but just kept going.  Reboot the computer and the connection came back for both wired and wireless.  Hope this helps someone else.
