fix problem "local only" when connection is across a wireless connection
2008-12-29T21:58:54+00:00
access point appear: unidentified network
internet appear bloqued
access: Local only
connection: wireless connection.
Please help check what is the reason "local only".
ip is assigned automatically by DHCP, but is not possible to connect to internet, the problem appear only on windows vista Pcs, in my other computer with XP version the connection is good.
I have Microsoft Windows Vista Home Premium SP1.
69 additional answers
    2011-11-05T03:48:36+00:00
    Had the same problem. Uninstalled the driver for the Atheros AR5007EG and reinstalled the version 9 driver. The driver update function told me that the driver was already up to date, but it was only at 7.2 or something. So I manually uninstalled it and installed the newer version that I had downloaded from the manufactures website. This computer was having the problem when connecting to wireless router - Linksys WRT54GL. Hope this helps!
    2011-11-11T21:23:32+00:00
    I uninstalled the Realtek RTL8187B WLAN card then ran a hardware scan... 'Local and Internet' now showing.  Job's a good 'un!
    2011-11-13T14:46:40+00:00
    To follow up:
    http://support.microsoft.com/kb/299357
    Has auto fix-it
    As well as expanded cmd process.
    2011-11-17T15:40:54+00:00
    I'm in the driver atheros driver 5700 camp.  Thanks everso for posting that solution.  It has done the trick for me, after several days of using a cable, I am back on wireless. Good stuff.
