fix problem "local only" when connection is across a wireless connection
2008-12-29T21:58:54+00:00
access point appear: unidentified network
internet appear bloqued
access: Local only
connection: wireless connection.
Please help check what is the reason "local only".
ip is assigned automatically by DHCP, but is not possible to connect to internet, the problem appear only on windows vista Pcs, in my other computer with XP version the connection is good.
I have Microsoft Windows Vista Home Premium SP1.
69 additional answers
    2008-12-29T22:14:24+00:00
    This appear on my PC
    2008-12-30T19:43:06+00:00
    Hi tirofijo,
    Thank you for taking the time to post your issue.
    I’m going to need you to answer a few questions for me.
    1.       When did this first start?
    2.       Have you ever been able to use the wireless?
    3.       What is the make and model of the router and wireless card you are using?
    Can you please bypass the router and hook the Ethernet cable directly from the modem to your computer and check to see if you can access the internet?
    The following Microsoft Article goes over a certain situation where Windows Vista cannot obtain an IP address from certain routers. It does include steps to attempt to address the issue but I would like to know the outcome of bypassing the router before proceeding with the steps outlined in the article.
    Windows Vista cannot obtain an IP address from certain routers or from certain non-Microsoft DHCP servers
    http://support.microsoft.com/kb/928233
    Keith
    2009-01-05T19:00:17+00:00
    This problem has always existed in Vista.  It happens on over 20 Dell Vista PCs we have purchased.  Problem never happened before with Windows XP.
    It seems that it will say "local connection only", then we diagnose the problem and it renews the IP address, then it works, but it is sure annoying.  Maybe someone at Microsoft can fix this with a Windows update patch, please!
    Seems to happen with Linksys, Netgear, Belkin and other routers.
    Jon
    2009-01-05T19:01:27+00:00
    I wanted to state that I have tried this fix, it doesn't seem to fix the problem.
    http://support.microsoft.com/default.aspx/kb/928233
