Programs Crash, error: Fault module kernelbase.dll . Application crash
2010-03-17T21:13:51+00:00
I have several programs that seems to be in some conflict with kernelbase.dll. They crash the moment I start them and kernelbase.dll is the fault module.
I've tried installing windows twice but the problem persist.
I've tried running in 'clean boot'.
I've tried 'Windows Resource Protection'
I've tried running the program in different compatability states.
Nothing helps. Any ideas?
The error message is pasted below:
Description:
  Stopped working
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    MDataTools.exe
  Application Version:    2.0.758.0
  Application Timestamp:    4b210990
  Fault Module Name:    KERNELBASE.dll
  Fault Module Version:    6.1.7600.16385
  Fault Module Timestamp:    4a5bdaae
  Exception Code:    e0434f4d
  Exception Offset:    00009617
  OS Version:    6.1.7600.2.0.0.256.48
  Locale ID:    1044
2011-01-21T05:21:36+00:00
I guess you have answered it yourself. User Profile corruption.
Log in as a different User. rename the problem profile. Log in as the original user again. A new profile will get created. If the crash is gone, copy your over your user data from the corrupted one.
If it does not solve the issue. Repeat steps with default folder too. This is the template profile, when creating new profiles.
regards
Martin
55 additional answers
    2012-10-27T08:23:07+00:00
    I have just tried a slight variation of your suggestion.
    I set a password for, and enabled the "Administrator" account, then logged into it, and tried once again to run the program that was giving me the trouble (Boxer Text Editor, which has never given me any problems in the past).
    The same problem occurred, even though the Administrator account was totally new.
    I have not tried renaming any other profiles or folders yet.  I take it that you mean the folders containing the profiles should be renamed and new ones created, is that correct?
    Thanks in advance for any help!
    Best regards
    Christopher Souter
    (Sydney, Australia)
    2012-11-24T04:57:31+00:00
    I got this one:
    Description:
    Stopped working
    Problem signature:
    Application Name: Magicka.exe
    Application Version: 1.4.10.0
    Application Timestamp: 5087ef54
    Fault Module Version: 6.1.7601.17932
    Fault Module Timestamp: 50327672
    Exception Offset: 0000c41f
    OS Version: 6.1.7601.2.1.0.768.3
    Locale ID: 1033
    Any ideas?
    2012-11-25T22:18:33+00:00
    I don't think that this will qualify as an "Answer," but I did manage to solve the problem.
    After trying unsuccessfully to solve the problem using most of the suggestions in this thread, I gave up and decided to try something else, and it worked.
    However, this "solution" didn't involve following any of the suggestions in this thread.
    My "solution" was:  Install Windows 8!
    It updates kernelbase.dll to a new version, and my problem went away immediately.
    I was always convinced that the problem lies with kernelbase.dll, and none of the "faulty" programs mentioned in this thread.
    I don't know how useful this will be to any of the contributors to this thread, but it's my 2 cents' worth, anyway.
    Best regards to all
    Christopher Souter
    (Sydney, Australia)
    2013-02-01T20:34:22+00:00
    Description:
      Stopped working
    Problem signature:
      Locale ID:    1044
    My issue with KERNELBASE.dll occurs with Nero Kwik Media 12:
    Log Name:      Application
    Source:        Application Error
    Date:          02/01/2013 12:09:10
    Event ID:      1000
    Task Category: (100)
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Computer:      DV6647cl
    Description:
    Faulting application name: KwikMedia.exe, version: 1.18.100.100, time stamp: 0x50885994
    Faulting module name: KERNELBASE.dll, version: 6.1.7601.18015, time stamp: 0x50b83b16
    Exception code: 0xe0434352
    Fault offset: 0x0000812f
    Faulting process id: 0x1be4
    Faulting application start time: 0x01ce00b7cfba2870
    Faulting application path: C:\Program Files\Nero\KM\KwikMedia.exe
    Faulting module path: C:\Windows\system32\KERNELBASE.dll
    Report Id: 3d64cd80-6cab-11e2-b90a-e56e27ef38a8
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
      <System>
        <Provider Name="Application Error" />
        <EventID Qualifiers="0">1000</EventID>
        <Level>2</Level>
        <Task>100</Task>
        <Keywords>0x80000000000000</Keywords>
        <TimeCreated SystemTime="2013-02-01T20:09:10.000000000Z" />
        <EventRecordID>165724</EventRecordID>
        <Channel>Application</Channel>
        <Computer>DV6647cl</Computer>
        <Security />
      </System>
      <EventData>
        <Data>KwikMedia.exe</Data>
        <Data>1.18.100.100</Data>
        <Data>50885994</Data>
        <Data>KERNELBASE.dll</Data>
        <Data>6.1.7601.18015</Data>
        <Data>50b83b16</Data>
        <Data>e0434352</Data>
        <Data>0000812f</Data>
        <Data>1be4</Data>
        <Data>01ce00b7cfba2870</Data>
        <Data>C:\Program Files\Nero\KM\KwikMedia.exe</Data>
        <Data>C:\Windows\system32\KERNELBASE.dll</Data>
        <Data>3d64cd80-6cab-11e2-b90a-e56e27ef38a8</Data>
      </EventData>
    </Event>
