Programs Crash, error: Fault module kernelbase.dll . Application crash
2010-03-17T21:13:51+00:00
I have several programs that seems to be in some conflict with kernelbase.dll. They crash the moment I start them and kernelbase.dll is the fault module.
I've tried installing windows twice but the problem persist.
I've tried running in 'clean boot'.
I've tried 'Windows Resource Protection'
I've tried running the program in different compatability states.
Nothing helps. Any ideas?
The error message is pasted below:
Description:
  Stopped working
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    MDataTools.exe
  Application Version:    2.0.758.0
  Application Timestamp:    4b210990
  Fault Module Name:    KERNELBASE.dll
  Fault Module Version:    6.1.7600.16385
  Fault Module Timestamp:    4a5bdaae
  Exception Code:    e0434f4d
  Exception Offset:    00009617
  OS Version:    6.1.7600.2.0.0.256.48
  Locale ID:    1044
2011-01-21T05:21:36+00:00
I guess you have answered it yourself. User Profile corruption.
Log in as a different User. rename the problem profile. Log in as the original user again. A new profile will get created. If the crash is gone, copy your over your user data from the corrupted one.
If it does not solve the issue. Repeat steps with default folder too. This is the template profile, when creating new profiles.
regards
Martin
55 additional answers
  1. Deleted
    2011-10-25T07:58:02+00:00
    Fantastic! Despite PowerPoint crashing at the stroke of a key, it never occurred to me that the keyboard driver might be involved. Many thanks!
    System: Windows 7 Professional 64-bit on a MacBook Pro (Lion) running Bootcamp
    2011-12-06T18:46:29+00:00
    I had a similar problem with Kernalbase.dll.  I tried re-naming the profile but it didn't clear the fault problem.  Next I created a new profile and copied the old profile data to the new as suggested.  The new new profile worked fine without errors but I had to re-register with a lot of my programs and games and change a lot of pointers to the area were I store all my pix, docs, videos, game saves and such so all of users can see the files and I can back them up En-mass. What a PAIN! It took hours. Windows keeps making it harder to configure the hdd the way I like it by insidiously squirreling my files away in hidden directories.
    Thank you to the people that offered suggestions. your help is appreciated.
    2012-03-05T19:26:56+00:00
    Which did you uninstall and reinstall? IE or Silverlight?
    Al
