Programs Crash, error: Fault module kernelbase.dll . Application crash
2010-03-17T21:13:51+00:00
I have several programs that seems to be in some conflict with kernelbase.dll. They crash the moment I start them and kernelbase.dll is the fault module.
I've tried installing windows twice but the problem persist.
I've tried running in 'clean boot'.
I've tried 'Windows Resource Protection'
I've tried running the program in different compatability states.
Nothing helps. Any ideas?
The error message is pasted below:
Description:
  Stopped working
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    MDataTools.exe
  Application Version:    2.0.758.0
  Application Timestamp:    4b210990
  Fault Module Name:    KERNELBASE.dll
  Fault Module Version:    6.1.7600.16385
  Fault Module Timestamp:    4a5bdaae
  Exception Code:    e0434f4d
  Exception Offset:    00009617
  OS Version:    6.1.7600.2.0.0.256.48
  Locale ID:    1044
2011-01-21T05:21:36+00:00
I guess you have answered it yourself. User Profile corruption.
Log in as a different User. rename the problem profile. Log in as the original user again. A new profile will get created. If the crash is gone, copy your over your user data from the corrupted one.
If it does not solve the issue. Repeat steps with default folder too. This is the template profile, when creating new profiles.
regards
Martin
55 additional answers
    2017-02-08T18:50:31+00:00
    I had the same problem (Exception code 0xe0434f4d in Kernelbase.dll) when I tried running a program in Win10 that ran on WinXP and Win7.
    In my case, the program used DirectX9.  However, Win10 seemed to already have it (or the later versions were said to be backwards compatible...or maybe I just assumed that to be true) so I didn't install it.  That was the problem.  Once I installed DirectX9 it worked like a charm.
    Hope that helps someone else with this problem.
    2017-08-23T16:07:59+00:00
    please solve it or send me method how  to solve it  plz please
    2017-08-26T13:22:17+00:00
    i m not working microsoft office
    i uninstall for my computer
    than try install in system because preious version exist my system it uninstall from my system i unsinstall very of my system
    i have liecence microsoft office 2010 and also micrsoft office 2013
    this problem show in my system
      Application Name: GROOVE.EXE
      Application Version: 14.0.7113.5005
      Application Timestamp: 52b23f0c
      Fault Module Version: 6.1.7601.23775
      Fault Module Timestamp: 58f4dbfb
      Exception Code: e0000002
      Exception Offset: 0000845d
      OS Version: 6.1.7601.2.1.0.256.1
      Locale ID: 1033
    Additional information about the problem:
      LCID: 1033
      skulcid: 1033
    Read our privacy statement online:
      http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
      C:\Windows\system32\en-US\erofflps.txt
