Programs Crash, error: Fault module kernelbase.dll . Application crash
2010-03-17T21:13:51+00:00
I have several programs that seems to be in some conflict with kernelbase.dll. They crash the moment I start them and kernelbase.dll is the fault module.
I've tried installing windows twice but the problem persist.
I've tried running in 'clean boot'.
I've tried 'Windows Resource Protection'
I've tried running the program in different compatability states.
Nothing helps. Any ideas?
The error message is pasted below:
Description:
  Stopped working
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    MDataTools.exe
  Application Version:    2.0.758.0
  Application Timestamp:    4b210990
  Fault Module Name:    KERNELBASE.dll
  Fault Module Version:    6.1.7600.16385
  Fault Module Timestamp:    4a5bdaae
  Exception Code:    e0434f4d
  Exception Offset:    00009617
  OS Version:    6.1.7600.2.0.0.256.48
  Locale ID:    1044
2011-01-21T05:21:36+00:00
I guess you have answered it yourself. User Profile corruption.
Log in as a different User. rename the problem profile. Log in as the original user again. A new profile will get created. If the crash is gone, copy your over your user data from the corrupted one.
If it does not solve the issue. Repeat steps with default folder too. This is the template profile, when creating new profiles.
regards
Martin
55 additional answers
    2016-01-10T11:16:14+00:00
    What is the KB number of the update?
    I suggest you to place the computer in a clean boot state and check if there are any software conflicts.
    http://support.microsoft.com/kb/929135 (Applies to Windows 10)
    Note: To reset the computer to normal mode after troubleshooting, please refer to “**How to reset the computer to start normally after clean boot troubleshooting”**from the above article.
    Please update us with the status. We will be glad to assist you.
    2016-02-23T16:27:26+00:00
    I don't know if this will help anyone or not.
    I was having a problem where Outlook was continually crashing.  I am running Windows 10 Enterprise and Outlook 2016.
    I found out that I had 2 problems.  Problem 1 was that I could not create PST files.  It would give me an unspecified error.
    I fixed problem 1 by adding the following registry key:
    HKCU\Software\Microsoft\Office[Version#]\Outlook\
    REG_EXPAND_SZ
    ForcePSTPath
    Value - [Your chosen path]
    Problem 2 was that Outlook kept crashing repeatedly and I received the same kernel error as mentioned several times in this string.
    I ended up changing my compatibility settings for Outlook to Windows 7 and set Outlook to run as an Administrator.
    Afterwards Outlook stopped crashing and worked as expected.
    I changed the setting by right clicking on Oulook, going to properities, and changing the options on the compatibility tab.
    I hope that this helps.
    2016-02-28T08:13:42+00:00
    Thank you for keeping us updated. This might be helpful for the users who are experiencing the similar issue.
    Please feel free to post if you need further assistance. We will be glad to assist you.
    2016-06-05T00:14:34+00:00
    Right click on the application you are having issues with > Troubleshoot compatibility > Try recommended settings > Test the program.  that should tell you what your problem is
