In the Screen Resolution window, under Change the appearance of your displays , click and drag one of the monitors to its correct location vs. the other one. The Identity numbers don't matter.
How to Swap Display Identity (Identities)
Windows 7 - Display 'A' Philips primary display - Display 'B' IBM secondary display. A shows as Identity 2 and B shows as Identity 1. I want to reverse these. Reason is that the cursor currently travels from display B to A and I need it to go the other way - due to physical location of displays
129 additional answers
2013-08-27T16:20:13+00:00 Try swapping the eizo and Sony TV when the TV is connected in the AMD Catalyst Control Panel -> Desktop Management -> Creating and Arrange Desktop, click on the black arrow on the main display and press swap?
I believe it stores different profile when you plug in different things, so you just have to set it correctly for each scenario.
2013-10-31T13:49:43+00:00 Still no news about that da*n issue...?
2013-11-05T00:35:13+00:00 In the Screen Resolution window, under Change the appearance of your displays , click and drag one of the monitors to its correct location vs. the other one. The Identity numbers don't matter.
I love it when people answer the wrong question. DERP DERP DERP I undersand nothing, allow me to vomit.
Still need a solution to this problem. Should be as simple as a right click, assign monitor identity. Seriously. Fix it. Now.
2013-11-07T10:01:27+00:00 ANY NEWs HOW TO CHANGE MY PRIMERY DISPLAY TO SECONDARY??? or how to change Identities? Because my primery display is 2#!!!
It is really stupid you caant set this. Its 2014 year almoust and when I am pushing win+p I have to set projektor (second screen) to my primary dispaly.
I have TV HDMI-HDMI, LCD Benq DVI-DVI
